Results 1 to 9 of 9
Thread: Installing AG pool need advice!!!
    Jun 2008
    Patterson , LA
    58
    Well after three weeks of prepping my pool(30'x54"wall Tahitian AG pool) site and alot of sweat labor our pool arrived yesterday.
    I have a major concern on the plumbing of the filter unit to the pool though. There is no specific instructions on this but here is what I have... 1 1/2 HP Sta Rite Mod canister filter and a wide mouth skimmer. The electrical plug for the pump is very short(maybe 3 feet at most). The black hoses that came with it look very cheap and cheesy. Can i use sch 40 PVC instead and bury it? Also how far away can I set the filter unit from the pool?
    I am going to be building a 3ft deck all around the pool in the future and would hate for the filter unit to cause problems with that later on.
    I also would think that haveing a ball valve in the skimmer and return line would be normal but none came with the set up. Am I thinking right that if you do not install valves then if you ever had problems down the line you would have to drain the water down to make any repairs?
    Thanks in advance
    RonnieM
    Tahitian 54" x 30' Round AG 23,000gl
    Sta-Rite 1 1/2 H.P 150 SQ. FT. Advanced MOD Media CartridgeFilter System
    50ppm Borate
    Liquidator 4 Gal
    TF-100 Test kit
    First time pool owner 2008
    BBB from the start
    Jun 2007
    Hunterdon County New Jersey
    19
    Re: Installing AG pool need advice!!!
    I just finished my AGP install and can comment on a few of these questions.
    As for the pump cord, 3ft is max length per the electrical code where I live. I also had to use a twist lock outlet. Make sure your outlet is a GFCI. No extension cords allowed (per NEC).
    I used Sched 40 PVC for most everything. I feel it will be more reliable than those pool hoses. Yes, it can be buried. But if you live where it can freeze, make sure you put a drain plug in the lowest section. You can have long lengths too (I have over 20 feet to include my solar).
    I did not use a valve at the skimmer. My skimmer and return both have NPT threads inside, and I just put in a plug when I want to do maintainance without draining.
    Jason M
    15x30 AGP built myself in 2008: 3/4 hp 2-speed Waterway Supreme. 300 lb Pentair sand filter. 160 SqFT solar.
    Jun 2008
    Patterson , LA
    58
    Thanks for the info.
    I have a Nema 3R rated breaker box with 110v 20 amp GFCI breakers that I plan on installing near the pool for power. The 220v breaker in my house is also GFCI that feeds it.
    No real freezing problems here in South Louisiana.
    I was suprised to see a regular 110v plug on the pump instead of a twist lock. Should I change it out to a twist lock?
    I have a digital intermatic timer( P1353ME) that I am going to hook up to the pump to help automate things a bit.
    50ppm Borate
    Liquidator 4 Gal
    TF-100 Test kit
    BBB from the start
    Apr 2008
    Manitoba, Canada
    17
    Good pool choice! We installed that exact pool in May.
    You may have done a better job of reading the instructions than I did but in the case that you didn't, the biggest "If I knew then what I know now" for me was not realizing that the v-bead liner could be converted to a slip bead liner. Had I know this I could have set up the entire pool, all the supports, posts, top rails, everything before having to worry about the liner.
    Our pool is not perfectly round, the sand under the liner is not perfectly flat, largely due to the fact that the pool walls kept wanting to blow over when we were trying to put the v-bead liner on.
    Our pump and filter is sitting about 30' away from the pool using 1 1/2" Sched 40 pvc. It works really well.
    Good luck with the install!
    30' round AGP - 54" vinyl - 80,000 liter (23,000 USG)
    Sta-Rite 150sqft Mod Media filter w/1.5hp Pump
    3 2x20 Sungrabber Solar panels
    Jun 2008
    Patterson , LA
    58
    Thanks a ton for the tip. So you think it is worth the extra $$ to get the clips to use the liner as a Beaded liner.
    I am very nervous about trying to install the wall and liner. Thats one heavy wall box. Do you have any pics of your pool? I would love to see one set up...besides the web sales pics
    50ppm Borate
    Liquidator 4 Gal
    TF-100 Test kit
    BBB from the start
    Apr 2008
    Manitoba, Canada
    17
    Hi, sorry for the late reply.
    The wall is a heavy beast. I used a 3/4" thick piece of plywood with straps hooked onto it to pull the wall around the pool. Me, my wife and our two teenagers were all needed to put the wall up.
    The instructions to use the cardboard to move it around were beyond optimistic.
    If you buy the beaded liner, the clips come with it.
    Good luck! (If you haven't already finished the build )
    Here is a nearly finished photo from our second story. (a bit more railing and a gate to build yet)
    Here are some build sequence pics.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    If you do not have the ability to install plugs in your skimmer and returns on the fly, installation of ball valves is one of the best decisions you can make during the pool setup process. There are so many things that can go wrong or need maintenance - the valves make it easy to work without water loss. You can purchase them at any home improvement outlet. Good luck and please post pictures - we love them!
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Jun 2008
    Patterson , LA
    58
    Thanks for the pics. Our install went well for never putting a pool together. I see you used a laser leveler as well. Those things are awesome.
    50ppm Borate
    Liquidator 4 Gal
    TF-100 Test kit
    BBB from the start
    Apr 2008
    Manitoba, Canada
    17
    I found your pics, looks like a successful install too!
    They are awesome, my Dad's tractor with front end loader was awesome as well
    Enjoy your pool.
