Results 1 to 10 of 10
Thread: No pool circulation for 80 hrs
    Sep 2013
    DFW Metroplex
    119
    Hello All,
    Today during my DE filter cleaning I noticed that 4 of my DE grids has multiple tears and others also in very bad shape, I ordered replacement from amazon and i should get that my late monday 05/19/2014 and I won't be starting my pool pump until 05/20/2014, what are my options here? I don't want to get any algae infestation again last November I went through a painful & lengthy slam process to get my pool water right, since then I am following TFP method , water is crystal clear.
    My Current reading
    FC - 6 ( Every 24 hours add 40 Oz of 8.25% bleach to maintain at 6)
    CC - 0.5
    CYA - 40
    CH - 280
    ALK - 65
    PH - 7.8
    Also my Hayward backwash value is very hard to pull(push pull model -- push&pull) , my spouse has been complaining about it for a while, will I be able to replace to this?
    Thanks everyone
    13K gal, IG, Gunite pool with raised spa water spill over to pool, built on 2005
    1.5 HP Hayward MaxFlo VS - June 2014
    DE Filter Model # DE6020
    Added Borates on Jun 2014
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: No pool circulation for 80 hrs
    Keep adding the bleach and use the pool brush to mix it.
    They show that multiport valve being compatible with your filter. The plumbing may not line up exactly, though. It never does.
    38,548
    I went 2 weeks without a pump in the AZ summer ... dirty pool, but no algae. You just have to keep adequate FC in it and brush to mix. I might suggest raising the FC a little higher than normal since the mixing will not be as good with the brushing.
    Sep 2013
    DFW Metroplex
    119
    Thanks Richard, I will continue to brush it up.
    Jun 2007
    New Jersey
    653
    I once went ten days without a working filter. I dropped my Rule cover pump with a 50' hose by the main drain and left the hose outlet pumping in to the shallow end. Every day or two I moved the hose somewhere else. I ran it 24/7 and no problems. I hate brushing. A submersible sump pump would also work.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Sep 2013
    DFW Metroplex
    119
    Thanks Jason, your other post on how to clean a DE filter with lot of great photos is my inspiration for doing this project by myself.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Keep the FC level up and remember circulation beats no circulation, this is what I rigged up when I had suction line / pump problems a couple of years ago using a small diesel 4HP water pump .
    Sep 2013
    DFW Metroplex
    119
    I have been suspecting water loss for a while, after making few repairs by myself, I did a test and I lost 5/8 th of an inch in 60 hours (I run pump 10 hours daily). The weather here in Dallas Tx is around high 80's for past three days. I assume I am in the allowed range? Trying to avoid professional leak detection as they charge $450.
    Richard320's Avatar
    Jan 2010
    19,075
    Quote Originally Posted by missourian View Post
    If it was windy, that's not unreasonable. The best way to check is to do a bucket test. Fill a plastic bucket with pool water and set it on the steps. Mark the level inside and outside. The water level should drop the same amount over a period of time.
    Sep 2013
    DFW Metroplex
    119
    Thanks Richard, I will be doing the bucket test this long weekend
