Thread: There is NO "no flow" light
    Dec 2009
    Palm Springs, CA
    24
    Topic split. Please ask questions in your own topic, rather than hijacking someone else's existing topic. JasonLion
    I have the opposite problem; there is NO "no flow" light when the pump is off. I removed the switch (yes, it was installed with the mark on the top) and tested it for continuity at the phone jack. There is none, even with the flapper held closed. This makes no sense at all to me....I tried cleaning the contacts with emery paper with no luck.
    18k gallon in ground plaster with attached spa
    Pentair CCP 320 cartridge filter
    Goldline Aqua Rite SWG
    IntelliFlo VS pump
    Teledyne Laars ESC heater
    Hayward Pool Vac Ultra cleaner w/ skimmer Vac Plate and inline leaf basket
    Palm Springs, CA
    38,262
    Re: Testing a flow switch
    Sounds like you need to order a new switch.
