Results 1 to 7 of 7
Thread: Cartridge Filter - When to open air bleeder...
    Mar 2013
    CT
    349
    Starting my pool this year will all new plumbing. I know I need to initially fill the leaf basket on the pump with water. When I go ahead and switch the pump on for the first time, do I open the air bleeder on my cartridge filter prior to turning on the pump - or - do I wait for the pump to prime, get the system going and THEN open it to bleed the air.
    Thanks!
    Dan
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    38,272
    Re: Cartridge Filter - When to open air bleeder...
    You can open it any time, either before you turn the pump on or right after. I would not wait for prime though.
    30,415
    Interesting question because I think you can do it either way. If you open the bleeder just before turning on the pump, there is some MARGINAL less resistance as the filter fills. It's probably not enough to make any difference and you won't have any spray-out if you keep it closed.
    That said, for me it's kinda fun to leave it open and then try to close it quickly just before it starts to spray....stupid, I know, but fun.
    RIRSZ's Avatar
    Jul 2012
    Central New Jersey
    54
    Looks like I've been doing it wrong, I leave it open and wait for it to spray before closing. Does this damage the bleeder?
    George
    32k gal IG free form / Vinyl Liner (cement wall) / Jandy 2 HP FloPro
    LRZ400EN Heater / Jandy CV460 Cart. Filter
    Paramount Vantage in-floor pool cleaner / built April 2013
    Pool Equipment Picture (on Flickr)
    30,415
    Nope, no harm.
    38,272
    That is fine ... I let it spray too. I also occasionally open it back up to see if any air comes out ... none usually.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I open mine a few times during priming. Start the pump and let it run maybe 30 seconds, open 3 or 5 seconds then close. Repeat until water starts spraying out. Close, let it run a minute or so, open again to get whatever air may be left.
    Divin Dave,
