Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: question about slamming
    Apr 2012
    South east VA
    26
    This will be my first time slamming...I'm opening for the season and my water is green, so just have a question. It says to raise the FC shock level to your current CYA level. I have a swg pool, and right now my current cya level is 20. Do I just raise the fc level to 10 with my swg off? Or raise the cya level to at least 60 before I start to raise my fc level?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: question about slamming
    Keep that CYA low until you pass the SLAM criteria. Low CYA is great for SLAMing. SWG off during SLAM.
    Isolated Spa - 345 Gallons
    Apr 2012
    South east VA
    26
    Quote Originally Posted by JVTrain View Post
    Awesome, thanks for the quick reply!
    Feb 2014
    Central Minnesota
    5,080
    To be more complete, are you using an Approved Test Kit?
    Add your pool specs, equipment and test kit to your signature so the experts (that know more than I do) can easily help you when you post.
    When you do decide to add CYA, be aware results at 20 or less have potential for error. Therefore, use PoolMath to calculate how much you should add to get to 60 ppm CYA, if your actual final target is 70. Add that much, wait a week and retest. Go from there. You'd rather shoot low on CYA and bump up slowly when you get close as there is no way to lower without draining.
    Apr 2012
    South east VA
    26
    Thanks again and yea I am using TF 100 test kit.
    18' above ground pool - 7500 gallons
    Hayward Aqua-trol SWG
    TF-100 test kit with speedstir
    Casey's Avatar
    SW PA
    10,448
    SLAM to 10! Brush the pool and if there is anything on the bottom, rake it with a leaf rake to get it out. If you have steps in the pool, get them out as they harbor junk behind them. Sweep the pool and keep SLAM'ing!
    Do you have any test results we can have a look at?
    Apr 2012
    South east VA
    26
    Quote Originally Posted by Casey View Post
    I'm still in the process of getting my FC up. But my numbers were as of last night...
    FC 1.5
    CC .5
    PH 7.3
    TA 60
    CYA is 10
    I did put some more bleach in before going to bed, (added the amount according to poolmath) this morning my FC was at 6, I just added some more bleach and will check it in a couple hours. Once I do get it to shock level, what's the next step? Should I then add some stabilizer to get my cya up? And then perform an OCLT test tonight?
    Smykowski's Avatar
    Sep 2011
    3,065
    Test and redose as often as necessary to keep your FC at 10. Do this for as long as it takes until you pass all three criteria to call the SLAM complete.
    Apr 2012
    South east VA
    26
    Ok thanks, and once the slam is complete, then that is when I should raise my cya?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,530
    The more you keep you FC at SLAM level the faster you will clear your pool up. IF you can test every hour and add bleach as needed to get to SLAM level. After a while you will find that your levels are holding better so you can back off of the testing. You will see a pattern with your pool.
    Good luck!
    Smykowski's Avatar
    Sep 2011
    3,065
    Ideally, you should get your CYA up to 30 now and adjust your SLAM value accordingly. At a CYA of only 10, you will be losing a lot of chlorine to sunlight.
    Feb 2014
    Central Minnesota
    5,080
    Read more PoolSchool! Add enough cya to get to 30 but realize you don't need to bother testing for it for at least several days. Takes that long to test for it accurately.
    Apr 2012
    South east VA
    26
    So I think I am almost there. But still something in the pool, I imagine it because I haven't had a chance to vacuum, I had to order another one something wrong with mine, should be here Wednesday. I have been brushing though and using a leaf net to get the leaves out of the bottom. My question is, my FC is 11 right now, a drop from 15 last night, should I wait until it drops below 10 to add more bleach?
    Here are my numbers:
    FC = 11
    CC = .05
    PH = 7.2
    TA = 53
    CYA = added 4 lbs of it yesterday to bring it up to around 30.
    Feb 2014
    Central Minnesota
    5,080
    Now that the CYA is in the water, assume you have 30 CYA. Keep that FC at 12.
    Apr 2012
    South east VA
    26
    I have another question, my pressure from the return seems to be really low for the last couple days. I added the CYA through the skimmer slowly, I assume that is the issue, that it just hasn't all dissolved yet, should I be concerned, or just let the pump continue to run for a week or so?
    And also, after I'm done slamming, when should I turn my swg on, when the FC drops down to normal levels?
    Feb 2014
    Central Minnesota
    5,080
    You put the cya granules directly in the skimmer? We maybe should have been more specific about adding cya. It should go in a sock (or 2 or 3) and either then put in a skimmer or hung in front of a return (ideal). Adding directly to skimmer can indeed cause clogging, build up in your filter and you might even backwash out a good amount of it if it doesn't dissolve. CYA takes several hours or longer to dissolve depending on temperature.
    Apr 2012
    South east VA
    26
    Yea, I've read that it shouldn't matter though if you put it direct in skimmer or not, but the preferred is a sock. The directions on the container even said to pour direct in skimmer, Just not to backwash for 48-72 hours, so figure it couldn't hurt. So should I just let the pump continue to run for a week or so and if doesn't improve backwash then? Or any other thing I should do?
    Feb 2014
    Central Minnesota
    5,080
    Yeah. If you put it right in the skimmer, I'd avoid backwashing as long as you can. Give it plenty of time to dissolve. Has your pump pressure spiked up at all?
    I'm not overly familiar with SWG but I would say turn it on when you've passed SLAM criteria and FC levels have dropped to close to your target FC based on CYA.
    Apr 2012
    South east VA
    26
    Thanks for all your help. So here are my numbers as of today.
    FC = 11
    CC = .5
    TA = 80
    CYA = 60
    PH = 7.2
    CH = 110
    So my plan now is just to let my FC fall down to around 4 then turn on my SWG, I guess I should raise my PH also. But all the other numbers look fine to me. Does everything look good? The water is clear and OCLT has passed.
  20. Back To Top    #20
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Congratulations!
    I'd leave the pH alone. The SWG will take care of raising it. So will a bunch of splashing kids.
