Results 1 to 16 of 16
Thread: Forgot to balance PH before SLAMMING, what should I do?
    Apr 2014
    Mansfield, OH
    14
    All,
    I opened my pool and it was dark green and filled with Algea. So, I just installed a new Hayward Sand Filter and new sand and started slamming and forgot to adjust the PH before doing so.
    I Started on 05/14/2014. At dusk I poured in 4 gallons of 12% bleach. I tested FC the next night and was at 13.5 and my CC was at 1. Based on my CYA, I need to keep shock at 15. So, I poured in the recommend level of bleach. I've been trying to maintain that level at 15. I tested last night and was good. This morning when I woke up it was at 12.5. So, I poured in 52oz of bleach as recommended by the pool calculator. The pool looks better everyday, but now I notice it's getting cloudy. Is that a good sign or bad? I know PH readings are off if FC is over 10, so I guess I will have to wait before messing with that, correct? Any advice?
    20,000 gallon
    IG Vinyl Foxx
    Hayward S244T Pro Series Top-Mount 24-Inch Sand Filter with 1-1/2-Inch Vari-Flo Valve
    Pump ?
    Age of pool = 15 years old
    30,423
    Re: Forgot to balance PH before SLAMMING, what should I do?
    I would test the pH when FC is at it's lowest....usually in the AM or PM. If pH is 7.4 up to 8.0, that will be close enough. If it is higher or lower, post back.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    If it were my pool, I'd let the FC drop to about 6-8 or so then check pH, adjust, then back to SLAMing. I don't think you'd lose any ground on the SLAM process, just delay it by a few hours. If your pH was high and you lower it to proper levels, your chlorine is more effective (from what I recall in reading/Pool School).
    Isolated Spa - 345 Gallons
    Apr 2014
    Mansfield, OH
    14
    The lowest my FC has gotten over the past two days is 12.5. So, would that be low enough to test? Should I worry about TA?
    Thanks for the quick replies and advice. I really appreciate it! I love the new Taylor test kit.
    20,000 gallon
    IG Vinyl Foxx
    Pump ?
    Feb 2014
    Central Minnesota
    5,080
    No worries on TA until after you've finished SLAM. Then you can play with that when you get bored.
    Since you're not losing much FC daily, you're really not going to set yourself back by allowing the FC to drop to below 10 so you can test pH. I'd still do that and then resume SLAM.
    Smykowski's Avatar
    Sep 2011
    3,065
    ^^ I agree with this post.^^
    Apr 2014
    Mansfield, OH
    14
    Thank you guys, much appreciated!
    20,000 gallon
    IG Vinyl Foxx
    Pump ?
    Casey's Avatar
    SW PA
    10,448
    Make sure FC is under 10ppm to check pH.
    Apr 2014
    Mansfield, OH
    14
    My FC level was at 10 last night when I got home from work. So, I tested PH and it was 7.6.
    20,000 gallon
    IG Vinyl Foxx
    Pump ?
    Apr 2014
    Mansfield, OH
    14
    Just updating everyone!
    Everyday the pool looks better and better. Last night was the first night I didn't lose any FC, water clarity is improving. I can see the bottom all around pool except for the deep end.
    PH testing with FC at 15 is 7.6. So, I'm going to let the FC drop below 10 and test PH later tonight. It's still cold outside here in Ohio, so water temp is very cold. Thank you everyone for all your help.
    The nice Taylor testing kit has made things much easier.
    20,000 gallon
    IG Vinyl Foxx
    Pump ?
    30,423
    You would clear your pool faster if you kept your chlorine up at SLAM value and simply ignore your pH until the SLAM is complete. Either way is Okay but your pH does not need to be retested.
    Apr 2014
    Mansfield, OH
    14
    Just checking in. I can now see the main drain and pool is getting clearer everyday. The pool does still have a green tint to it, but water clarity is really improving. FC loss overnight is minimal to none.
    I'm trying to be very patient. Thanks for all your help. Still maintaining my shock level at FC 15. Won't stop until I pass all three of the SLAM tests.
    20,000 gallon
    IG Vinyl Foxx
    Pump ?
    30,423
    Good work, WDM. Patience is tough to have right now but stay the course. Thousands have been successful before you and thousands will follow.
    Apr 2014
    Mansfield, OH
    14
    Thank you everyone, my pool is crystal clear. You can see the main drain from all the way across the other side of my yard. It took about 10 days to get super clear!! You guys and all your support are awesome!
    20,000 gallon
    IG Vinyl Foxx
    Pump ?
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by whodaman View Post
    Yahoooo! You did it.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Congratulations!
    Pics?
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
