Thread: Testing kits
    May 2014
    United Kingdom
    1
    Testing kits
    Im in the UK and we have a small outdoor pool. I currently have strips, a palintest kit where you drop a tablet in and a aquachek Trutest handheld reader. Im getting completely different readings for TA from the handheld reader and the other two testers and im struggling as to which to trust. I cant justify buying a large semi pro testing product.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Testing kits
    Welcome to TFP!
    While we can't suggest the normal kit for you being in the UK, you should be able to obtain something more proper for Free Chlorine and pH. Test strips will get you in trouble at some point. They are simply not reliable enough to depend on. pH and Free Chlorine are far more important than TA in a pool such as yours. Most of them in fact.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Testing kits
