Thread: How many gallons is my pool?
    May 2014
    Poughkeepsie, NY
    17
    Hello
    I am new to TFP and first want to know the number of gallons in my pool. Its 18 x 36 rectangle, in-ground, 3 foot shallow and 8 foot deep end, but the deep end sides are slanted.
    I have seen estimates between 23,000 and 25,000 gallons from pool stores, and was wondering if that is correct.
    I have had my pool for a decade and the past few years have had trouble establishing chlorine at the beginning of the season, including this year.
    My FAS-DPD test kit will arrive on Friday, and I will test the water immediately when it comes. I have had conflicting numbers and recommendations from different pool stores this year, and last year wasted lots of money.
    So I am going the TFP method. Thought I would start with hopefully a simple question.
    Thanks
    -- Scott
    18 x 36 vinyl lined in-ground pool
    Hayward DE Filter
    Hayward Super Pump
    Hayward Propane Heater
    Casey's Avatar
    SW PA
    10,424
    Re: How many gallons is my pool?
    Welcome to TFP Scott! Congratulations on ordering a test kit and taking control of your pool!
    You can determine how many gallons are in your pool by using Pool Calculator Instructions. All the way at the bottom, you can plug your measurements in and walah....
    May 2014
    Poughkeepsie, NY
    17
    Thanks Casey
    The calculator told me 26700, since my deep end sides are sloping half way down, does that alter the calculation slightly?
    -- Scott
    Hayward DE Filter
    Hayward Super Pump
    Oct 2013
    Chapin, SC
    1,141
    Congrats, that's exactly what I got! Now go order your test kit from TFTESTkit.net get the XL option, You'll be glad you did ditto that with the speed stir!
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Jul 2011
    Arizona & California
    803
    Consider this way to determine the amount of gallons in your pool.
    http://www.troublefreepool.com/threa...ng-Pool-Volume
