Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 116
Thread: Please advise with help on pool
    Mar 2014
    Tennessee
    73
    This spring I joined the forum in anticipation of needing help with my pool this spring/summer. Either I have been unable to find it or there were changes in the forum, but I thought I recalled a forum where experienced members would help a newbie walk through "recovering" their pool. If this was the case can someone direct me to the appropriate place or give me a little direction on the best way to proceed? Sorry in advance if this was the wrong forum to post this question.
    Last edited by PoolnTN; 05-29-2014 at 10:55 PM. Reason: Added picture and corrected join date error
    32,500 gallon L-shaped IG vinyl, Built in early 1980's
    Aquabot Turbo T Jet
    Century Centurion 1.5hp pump
    Hayward sand filter: 300lb, filter rate 20GPM/ft2, flow rate 62 GPM
    30,421
    Re: Please advise on the best place to post.
    This forum is fine for you to post. The first thing we will need to help you get started is a set of current test results and then tell us how your water looks. Can you provide the test results?
    Mar 2014
    Las Vegas
    288
    You have the right place. Fire away with your questions. Plenty of good help here.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Casey's Avatar
    SW PA
    10,444
    We're here to help PoolnTN!
    Welcome to TFP! Have you read Pool School yet?
    Mar 2014
    Tennessee
    73
    Hey, thanks in advance,
    I did read pool school, thanks for the advice. However I'm afraid I'm much past that scenario now (tadpoles are jumping after less than one year??) I bought a house with a pool but with the addition of two tricycle motors I let that slide a bit. But I want to get it usable so that the little ones can play.
    Aquabot Turbo T Jet
    Casey's Avatar
    SW PA
    10,444
    Have you ordered a TF100 or K2006 test kit yet? If you have not, I would suggest getting the TF100 XL test kit.
    If it's full of water, let the pump/filter rip and get us a full set of test results (NOT from the pool store)! The test kit is a must have in pool ownership.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Mar 2014
    Tennessee
    73
    Quote Originally Posted by Casey View Post
    Thanks, I knew from previous reading on the board that I needed to get a test kit ASAP in order to be able to provide any information that would be useful. I will get the one you suggested on order.
    Not exactly, but thanks for providing the link since I'd been looking for that. I read it last winter and was looking for it also.
    Mar 2014
    Tennessee
    73
    First off thanks to everyone for the replies.
    Casey,
    I knew from previous reading that I needed to get a kit ordered ASAP. I will get the one you suggested on order. I plan on getting the filter going this weekend. The chlorine dispenser cracked over the winter (tree branch fell on it) so I plan on just removing it unless you guys think I need to replace it with another. I've got to pick up a few PVC elbows before I can do so.
    Richard320,
    Not exactly but thanks for the link. I found that last winter and had been looking for it.
    Also, a few quick questions for everyone:
    1. Should I attempt to continue scooping leaves out of the "abyss"? Or will I be able to clear it up without getting them out?
    2. Should I be concerned with how dirty the sand is in the filter? I have no idea when it was changed and I went through a similar process last year with an extremely dirty pool. I did backwash it regularly during the process, though.
    3. Is there a way to change my thread title to more accurately reflect the subject?
    Oct 2013
    Chapin, SC
    1,141
    1.Definitely, scoop out all that you can-- ALL !
    2. Backwash to clean the filter!
    3. I got here as will all the folks you need to help you, you can leave it as is!
    4. You'll get all the help here you need to get it sparkling blue!
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by PoolnTN View Post
    Also, a few quick questions:
    Scoop out as much as possible. Leaving them would dramatically slow the SLAM process.
    You might need to I suggest you deep clean the sand filter. Here - http://www.troublefreepool.com/threa...-a-Sand-Filter
    Go to the first post in the thread and edit the subject.
    Welcome to the forum
    You're done SLAMing when:
    Mar 2014
    Tennessee
    73
    Thanks, I will try to do the deep filter cleaning this weekend.
    Aquabot Turbo T Jet
    Mar 2014
    Tennessee
    73
    I'm about to order the kit. What options would you recommend getting besides the XL option? Do I need borate strips? I thought about adding the Speedstir since I read it seems to be worth it.
    Aquabot Turbo T Jet
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Please advise with help on pool
    You won't regret the SpeedStir ! 😎
    Jeff
    30,421
    Hold on the borates. That is something for later down the road and I would not encourage you to learn about them until you have had some practice keeping your pool in balance for maybe 300 days or so.
    Mar 2014
    Tennessee
    73
    Thanks. Entering my order now.
    30,421
    This should have been 30 days...not 300. sorry!
    Mar 2014
    Tennessee
    73
    Ha, I was thinking that hopefully I'd have it successfully closed by then!
    Mar 2014
    Tennessee
    73
    Just started the deep clean of the filter this morning. Wow. This is about 15 minutes in:image.jpg
    Aquabot Turbo T Jet
  20. Back To Top    #20
    Mar 2014
    Tennessee
    73
    Still going...
    It seems like I may need some more sand. It seems pretty low and it feels like there are a bunch of "valleys" in the sand when I move the hose around. How much of the barrel should it fill up? Do I need to get some more sand at a pool store or will a home improvement store have something that will work?
    Aquabot Turbo T Jet
