Thread: Pump impeller broken...replacement?
    I noticed yesterday that the pump was no longer pumping water. I opened the basket lid, and found the end-cap to the impeller laying in the pipe. I took the removed the motor from the basket-housing area and removed the top to find the broken impeller. The motor seems to be fine. I assume it should be possible to simply replace the impeller, but I'm kind of confused as to how it is connected to the shaft. Anyways, here's a couple pics. I didn't spend too much time looking at it - just kind of glanced and figured I'd rather do something else for the time being. Thanks.
    Here's the other pic https://www.dropbox.com/s/0qk4h7prkz0qcwb/2014-05-15%2018.45.21.jpg
    ~10,500gal IG Plaster; Hayward Sand Filter; Kreepy Krawly cleaner
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Pump impeller broken...replacement?
    What kind of pump do you have?
    Most impellers screw onto the motor shaft. It'll be a matter of removing any broken piece from the motor, and buying the correct impeller. Also, see if there's a part number stamped onto the broken impeller.
