Results 1 to 15 of 15
Thread: Test results
    Road scholar's Avatar
    May 2014
    Bowie, Maryland
    41
    Test results
    I completely drained and refilled the pool from a hose so the water is "fresh". To the eye it's crystal clear. I have a K2006 test kit on the way but in the mean time I took a bottle of water to the local pool store. This is the results and their recommendations. How does this sound?
    Results:
    PH 7.5
    Calcium hardness 90 ppm
    Total alkalinity 30 ppm
    CYA 10 ppm
    Recommended chemicals:
    31 lbs total alkalinity
    34 lbs calcium hardness
    6 lbs stabilizer
    Chlorine tabs
    60' x 20' L-shape, 23K gal, NSW, IG Plaster, built spring 2002, 3 HP Inteliflo pump, Cartridge filter, gas heater, swim lane, volleyball net, Dolphin A30i robot.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Test results
    Just being Nosy, but why did you drain?
    Have you read POOL SCHOOL? Click on the link at the Top of the screen. All sorts of helpful articles.
    I'm glad you have a test kit on the way.
    I'd ignore anything they told you. I didn't even verify, its just that after servicing 5 "Pool Stored" pools today... I'm crabby.
    Mar 2014
    Las Vegas
    288
    Re: Test results
    Not sure where you get your water, but there is never any CYA in tap water. Just more proof that pool store tests are unreliable. I'd add some of the CYA and some chlorine to get it up to at least 2 ppm.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Re: Test results
    Quote Originally Posted by Road scholar View Post
    Results:
    PH 7.5
    CYA 10 ppm
    6 lbs stabilizer
    Chlorine tabs
    It sounds suspicious. Tap water has no CYA in it. How much residual water did you have in the pool after draining it? Must have been a lot to show 10 ppm CYA. pH I'd trust for now. The others? Hmmmm.
    TA is just baking soda. Big bags are for sale at Costco. Stabilizer AND chlorine tablets? Both add CYA. You don't want to overdo it. Tablets also lower pH and TA, and you're already low on TA.
    You'll need a bunch of CYA. Pool volumes tend to be overstated. Maybe one 4 lb canister of CYA for now, in a sock, in front of a return. Leave it there until it dissolves. It will take a few days. You can always add more, once you know what it really is.
    In the meantime, add three quarts of 8.25% Chlorox or equivalent every day until you get the test kit and can adjust things properly. Somewhere in there, add a couple 7 lb bags of baking soda. It's really easy to add more later, but overdoing it will just make you use more acid later. Calcium? I'd hold off until I had test results I could trust.
    End prescription.
    May 2014
    Bowie, Maryland
    41
    Re: Test results
    Awesome advice, thanks. I completely drained the pool to do some repairs and sand some scaling. Pool is full of tap water, all 25K gal, plus some debris from the current storm and spring trees shedding.
    So CYA comes in canisters? Where is the best place to get that, pool store? Thanks for the tips on using bleach and baking soda. I started reading pool school. I'm heading out to the Blue Ridge on motorcycles as soon as the rain calms down but taking the iPad and will read the rest over the weekend. This is a good start. Thanks again.
    Richard320's Avatar
    Jan 2010
    19,034
    Re: Test results
    CYA is sold at pool stores, big-box hardware stores, possibly small hardware stores, and places like Walmart. It might be called Stabilizer.
    May 2013
    Fort Lauderdale, FL
    423
    Re: Test results
    You can get CYA at wal-mart for cheap. It's called "stabalizer", make sure ingredients say 100% cyanuric acid
    I get baking soda at costco as well as clorox bleach
    i think the only thing you "need" from a pool store is calcium "hardness". I have to add about 15 pounds at pool opening to keep up the CH for the season.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Oct 2013
    Chapin, SC
    1,141
    Re: Test results
    I sent my wife to walmart to pick up a 6.5 lb jug this morning, cost just over $20 including tax. https://www.dropbox.com/s/uc26ek882s...2016.02.39.jpg
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    May 2014
    Bowie, Maryland
    41
    Re: Test results
    I found stabilizer plus at walmart. It's granular and has some sulphuric acid in addition to cya. Is this ok?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Re: Test results
    I would steer clear of anything with "Plus" or "+Xtra" on it.
    This is what you need:
    Aqua-Chemical-Stabilizer-3lbs
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    May 2014
    Bowie, Maryland
    41
    Re: Test results
    Thanks.
    Questions:
    Do I pour the Clorox and borax into the skimmer or broadcast in the general pool water? Is there a section in Pool School that covers this?
    Oops, just found it in pool school!
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Re: Test results
    Don't put anything in your skimmer. Some products instruct you to do this, but trust me, it usually ends up at the very least making a mess and wasting product. Even worse you could end up clogging or damaging your equipment.
    Liquid bleach should be poured with the opening close to the water surface to avoid splashing, but do NOT use splashless varieties! Carefully aim the descending stream of bleach to intersect the water jet flowing out of the return so it mixes rapidly.
    Borax mixes pretty quick if broadcasted and swept with a brush. However I recommend putting the proper amount into a bucket of water and pre-dissolving it then pouring the mixture in front of the return just like the bleach.
    Thanks.
    Questions:
    Oct 2013
    Chapin, SC
    1,141
    Re: Test results
    http://www.walmart.com/ip/My-Salt-Po....5-lb/34752155 That'swhat you want-- you may have to order it site to store. it says my salt pool, but it works just fine with bleach too.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Re: Test results
    That's a much better deal than what I posted. 6.5lbs for only $19.97 vs 3lbs for 12.97. I wish my Walmart carried it.
    Quote Originally Posted by timerguy View Post
    Oct 2013
    Chapin, SC
    1,141
    Re: Test results
    Google it, it's available at numerous stores besides some walmarts. Fleet Farm and Menards and Kmart too are a few of them.
