Page 1 of 3 123 LastLast
Results 1 to 20 of 54
Thread: Test Results in on the Cesspit!
    May 2014
    Upstate NY, US
    64
    So on the good news front, I got my test kit and did my first test, and according to pool math, I have alot of work to do. So here are my results.
    PH: Off the charts, over 8
    CYA: Under 30 ppm
    Free Chlorine (FC): None
    Combined Cholorine (CC): None
    Alkalinity (TA): 50 ppm
    Calcium (CH): 30 ppm
    Picture of my cesspit:
    My pool: 13,500 gallons round pool, 24' w 52" above ground, hard sided pool. Jacuzzi 190L Sand Filter, 1 Horse Waterway pump, Robotic Vacuum
    May 2014
    Upstate NY, US
    64
    Re: Test Results in on the Cesspit!
    I also need some other help, I have a broken part on my filter, I think I know what it is, but I want to make sure I order the right parts.
    I believe the broken items are these two parts, what do you guys think?
    http://www.poolpartsonline.com/p-525...t-4628-17.aspx
    http://www.poolpartsonline.com/p-525...ool-parts.aspx
    Casey's Avatar
    SW PA
    10,441
    Welcome to TFP!
    I can't help you on your broken parts but you need to get the pH down asap with MA as soon as you get your water moving.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    From the looks of it you have some work ahead of you getting the rest of the broken parts out. Careful not to damage the threads too much or you'll be using lots of pipe thread tape & compound!
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    May 2014
    Upstate NY, US
    64
    It is on the agenda Casey!
    I just posted a pic to see if maybe anyone knew so I can make sure I order the right parts, as I have no pool store nearby, I have to order them online and I don't mind spending money, but I hate spending it on the wrong parts.
    Casey's Avatar
    SW PA
    10,441
    Good luck with that swamp! You should be good with the TF100! When you get it up and running... brush that beast til your arms fall off!
    May 2014
    Upstate NY, US
    64
    I got the k2006 but it is super easy to use and the box is handy as can be. I am super happy with it as the tests are super easy to do, even the powder one, as I don't remember what goes with what right now.
    May 2014
    Upstate NY, US
    64
    So, bad news, pump is no good. It's a Hayward 1 HP non-variable pump, any recommendations on what to replace it with?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Now would be a great time to get a 2-speed pump. What's your budget?
    May 2014
    Upstate NY, US
    64
    Fairly flexible, but I don't want to spend an arm and a leg (300+), as it's just an above ground.
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    If the pump itself is still okay, you'd be able to save $ by getting a motor only. (assuming of course that the motor is what crapped out)
    On the broken bits. before you order anything, make sure you can get the rest of the parts out....from the pic, to me, that looks like it may not be doable w/o trashing the housing it's in.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    May 2014
    Upstate NY, US
    64
    From what I see online, the motor is 130 and a replacement pump with strainer for the exact same thing is basically the same money (140), but I did get the gasket and the sight glass remnants out with no damage.
    May 2014
    Upstate NY, US
    64
    So last weekend we finally got everything running, I spent around half the day chasing leaks and getting those issues handled. So we finally got a chance to run everything and it ran like a top for most of the time. Began the slam process etc, unfortunately while I was sleeping, the diverter failed on the filter and all the water we had put in it went out the backwash hose (which I guess is better than it dumping six inches of water out of a 24' foot pool out the fitting or other places around the area where the filter is, since it is right next to the pool).
    I have the diverter repair kit coming (just ordered it today), I also got my gasket and sight glass, and installed those last night. I also ordered more CYA agent from Dave (I got the big bottle, no worries). We did tie off the back wash hose so it would really limit the amount of water coming out of it, but the problem is we blew a line off the discharge yesterday, so we have to watch it until we can double up on hose clamps (we are getting some and will put those on tonight), so if we run it, we have to have someone watching it until we can get it fixed.
    But the good news is we made progress, and my test results this morning were:
    PH: 7.4
    CYA: Under 30
    Free Chlorine: 0.6 ppm
    Combined Chlorine: 1 ppm
    Alkalinity: 60 ppm
    Calcium: 50 ppm
    Picture of it now
    Casey's Avatar
    SW PA
    10,441
    Well, it's certainly lighter but I'd actually hold off on everything til you get the pump/filter fixed and you can run the pump without losing water. Continue to read some articles in Pool School and when you start, you'll be so ready to slay the green monster!
    May 2014
    Upstate NY, US
    64
    So we got everything fixed Friday (Diverter repair kit was ordered Thursday and came Friday, made me happy). So I've been able to run everything around the clock and keeping an eye on the Chlorine levels. I've put enough stabilizer to go from 0 to 40 CYA). I did a test last night, I was at 7 ppm FC and 1 ppm CC, I added the necessary stabilizer and 140 ounces of Chlorine. This morning, I had 12 ppm FC and 1 ppm CC, I added 41 ounces of Chlorine. I tested two hours later and had 15 ppm FC. We are making progress, it is still light green and we are moving forward.
    Tested CYA, ended up at 35 ppm. The only concern I have is how it is bubbly on one side by the return/skimmer, but not on the other side of the pool.
    Just remembered how to get pictures off my iPhone... LOL
    May 2014
    Upstate NY, US
    64
    It's been about a month, but we have seen some progress!
    Go for TFPC and bleach!
    May 2014
    SW, MO
    58
    Have you cleaned out the pool yet? Made sure you don't have any piles of leaves or gunk down in the bottom? The more stuff that is down there the longer it will take. How have your #'s been running? Are you still slamming steadily or only when you get time? It definitely looks better than the pit LOL
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    progress is a good thing! looks much better!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    May 2014
    Upstate NY, US
    64
    Quote Originally Posted by poobears View Post
    Yes, I vacuum and brush daily. I also tossed the robot in and we shall see if it works. I am running 14 ppm FC per my 35 CYA. I check it 2-3 times a day.
    Also, I am not sure if my Hayward aquabug works, will it damage the pool if it sucks but does not move?
    Thanks!
  20. Back To Top    #20
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Oh, boy! poolporn!
