Results 1 to 15 of 15
Thread: Beaded liner installation help needed.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Beaded liner is torn from dry rot near the edge along the beading and needs replacement.
    I've gotten some quotes and they're, at the cheapest, $1,000 ($600 for 33x18 20g liner, rest is labor) or more depending on any additional floor prep needed.
    Is this a something that is doable for a determined DIY'er?
    Pool store is discouraging 25g liner stating it's to difficult to work with and will add $120 to price. But if I have to go through this I'd like something that lasts.
    I'm mostly concerned about what's under the floor and how to dry our or remediate any bed issues.
    Pool stores have said measurements are +/- a few inches on width and length. One say a custom liner needs to be ordered (more $$), the other says it should not be an issue to make stock fit work.
    Please advise if there's a thorough how-to on this site or elsewhere and your thoguhts on tackling this job.
    Thanks!
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    Jul 2007
    Hillsborough, NC
    525
    Re: Beaded liner installation help needed.
    1. You can install it yourself. I did. It was probably the easiest part of the job.
    2. I used a stock liner. It fit with no problems
    I would worry about the floor after you get the old liner out and can see what is there
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Casey's Avatar
    SW PA
    10,448
    Liners are not difficult to put in with a few buddies to help.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Watch a few of the youtube vids on replacing liners, gets some mates, and it will be over in less than a day...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    the 25 liner is also recommended. Whoever told you its more difficult is more lazy than anything else. Recommended to do the liner replacement on a warm sunny day. The sun heating up the vinyl will make the job a lot easier.
    Divin Dave,
    Jul 2007
    Hillsborough, NC
    525
    From my experience, you will want at least one other person, preferably two. I had two guys helping me. One pulled the liner up ahead of me and held it while I put it in the bead and the other guy kept it in behind us as we worked our way around the pool.
    May 2013
    Albany, NY
    59
    Onslow,
    to reiterate what others have said, you should have no problem doing this DIY with a helper. I'd go with the 25mil, btw.
    also, send my love to Daisy, and try to keep Hyacinth off your back
    Eric Adams, Technical Specialist, Radiant Pools
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Thanks all - I may just brave this. Sounds doable.
    What's the deal with using a shop vac during installation?
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    The shop vac is for suctioning the liner to the walls and floor so you get a nice fit...
    Jun 2012
    western NY
    1,560
    Quote Originally Posted by Onslow View Post
    Onslow
    You can see in this picture where the shop vac hose is under the liner (left edge of the shed) you can see how it has the liner sides pulled tight all the way around the sides. This helps greatly in getting all of the wrinkles out of the floor. Once the water started rising up the side walls, I just let the water smooth them all out.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Will things go badly if I don't have a shop vac?
    Casey's Avatar
    SW PA
    10,448
    No, they won't. Just work the wrinkles out any way you can if there are any.
    Jun 2013
    Manitoba, Canada
    153
    Don't forget to shop around on-line for a liner too. Lots of deals out there.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Thanks all! Installed and filling up today. This effort is now seeing the light of day thanks to helpful family and this forum!
    Attachment 31371
    I have several threads started over the past few months (was trying to keep subjects seperate) so sorry if you've seen this pic elsewhere.
    Casey's Avatar
    SW PA
    10,448
    That is an awesome liner! You will enjoy it thoroughly! Congrats!!!
