Thread: Hayward 2" union - is there a correct way for flow
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    416
    Is there an optimal way (direction of the threaded coupling) on a Hayward style Union.
    ie. should the threaded [ or larger side go with the direction of the water.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Re: Hayward 2" union - is there a correct way for flow
    It doesn't matter.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    If the union is on a vertical run you may want to put the half that has the o-ring groove at the bottom so you don't have to fight trying to keep the o-ring from falling on the ground when the union is separated.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
