Thread: Kreep Krauly issue
    May 2014
    canada
    33
    Kreep Krauly issue
    Hi, new pool owner here. Have just opened my pool this week and had to replace my sand filter so that was a little bit of a suprise expense.
    Now today I tried to get the vacuum going and it really did not work out well. I watched some instructional videos online and I think I did what I was supposed to. I pushed the kreep krauly all the way to the bottom of the pool, filled the hose with water and put the hose into the skimmer hole. When I turned the pump back on my filter top immediatly began spitting water out from where the top of the base meets the adjuster. Not sure why so I just stopped as I did not want to ruin anything.
    One thing I have learned is that there is a 2" adapter that I should have used to put my vacuum hose into the skimmer hole bc I dont have a threaded hole.
    But would not using that have caused the leak in the filter?
    Any help that can be offered would be great.
    Thanks.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Kreep Krauly issue
    Hi, welcome to TFP! It may be the collar that holds the multiport valve in place is not tight enough, or that an o-ring is out of place. Can you post a picture of the problem area?
    Love TFP? Become a
    TFP Supporter!
    May 2014
    canada
    33
    Tomorrow I will try tightening the collar and see what happens. If I still have problems I will post some pics and lots more info.
