Thread: Aqualogic Cell Power
    Jul 2011
    Las Vegas, NV
    37
    I've got a SWCG that's currently reading "Cell Power Error." Following guidelines on this forum, I pulled the main board to see of there was any burned spots behind the K1 joint. Doesn't look like that's the problem:
    Am I missing something? I'm not all that experienced with electrical components, but it appears that the solder is good. Is there a second-most common failure that kicks out that error message?
    33k in-ground plaster pool and spa / Goldline T-15 SWG w/ Aqualogic controller / RS2000 Hayward pump / Pentair Clean & Clear Plus 420 sq. ft. cartridge filter
    Re: Aqualogic Cell Power
    You can get the same error if there is a problem with the cell cord getting cut, and for certain kinds of rare power supply failures.
    Jul 2011
    Las Vegas, NV
    37
    Quote Originally Posted by JasonLion View Post
    The cell itself is only 1 year old. When I pulled the board and replaced it, the error went away for a while, but it came back. I've made sure the cord is set firmly in the socket, but how would I test if there was a problem with the cord?
    Cord problems are usually obvious cuts or gouges in the cable, or places that are browned and burnt.
