Results 1 to 14 of 14
Thread: Pool edging
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Pool edging
    Can you please post a photo of your pool edging? I cannot make up my mind what to do... to use plastic edging or maybe some bricks or composite edging or maybe steel edging... too many choices
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Jul 2007
    Hillsborough, NC
    521
    Re: Pool edging
    My edging is a deck around 3/4 of the pool. The last side has (or will have) river rock.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Pysiek's Avatar
    Apr 2012
    419
    Re: Pool edging
    I do have rock around my pool. But I would like to separate grass from the rock so it look nicer
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Re: Pool edging
    Here's mine. Rinox Spherik Coping.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Jul 2007
    Hillsborough, NC
    521
    Re: Pool edging
    Do you have above ground or in-ground pool? You posted this in above ground, so I assume it is an AGP. If you have rock around the pool already, I'd go with steel or plastic edging to contain the rock. and let the grass grow right up to the edge. I wouldn't do a wider border than that, but that's just me.
    Casey's Avatar
    SW PA
    10,427
    Re: Pool edging
    Crokett, Steve's pool is an in ground. We get a lot of in ground members who frequent the above ground section of TFP.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Re: Pool edging
    Woops! Didn't even see that. I got to the post through the New Posts feature. My bad.
    Casey's Avatar
    SW PA
    10,427
    Re: Pool edging
    It's ok Steve! Wish I could get an above ground like that though!
    Oct 2012
    Central Ohio
    180
    Re: Pool edging
    steveg_nh's pool is the new Sharkline Barracuda series,only for those serious about relaxation. It's a partial bury.
    I've got natural 57's (basically river rock)with plastic edging around my pool,sorry I don't have a pic at the moment.Although it looks similar to this pool.
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Pool edging
    I plan to use marine grade 67mm thick rope around the base of my rectangle pool, kinda going with a nautical theme. This will help hold the river rocks back from the very edges of my Intex liner, then my pool will be framed with embedded-into-the-ground railway sleepers to rest the legs of the pool on, and then I will artificial turf the 11m2 of space I have left.... I like the combination of wood, rock and grass....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Casey's Avatar
    SW PA
    10,427
    Re: Pool edging
    Mine is still currently a mud hole!
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Pool edging
    Quote Originally Posted by Casey View Post
    Yes but you're getting a deck... Can't wait to see that build....
    Casey's Avatar
    SW PA
    10,427
    Re: Pool edging
    Yep! It needed to be done last year! I'm excited about having a more finished look. These projects are never done though! You always find something else to add or do.
    Pysiek's Avatar
    Apr 2012
    419
    Re: Pool edging
    I do have AGP. Did anyone used bricks or some kind of rocks?
