Results 1 to 8 of 8
Thread: Low Amps/ Low Volts Pool Pilot
    Just started up my Pool Pilot SWG for the season and I'm getting an error message Low Amps Bad Cell? Test reads between 0 and 10 volts and less than 1 amp. I replaced the cell with an RC 42 and cell cord 2 years ago so they are still relatively new. Since last season I've been having some issues with the tri flow sensor reading some wacky numbers, (ex: 100 degrees/ very low salt and an occasional bad temp sensor error) but would usually straighten out after moving the cord around a little bit and recalibrate salt. So I'm guessing I need to replace the tri flow sensor this year, but could this resolve the low amps/volts problem also or am I looking at a completely different problem with that?
    Thanks for any help, very much appreciated!
    Re: Low Amps/ Low Volts Pool Pilot
    The low amps/volts issue is separate from the tri-sensor issues you have had before.
    Try activating the cell by pressing the BOOST button, let it run a few minutes, then do the TEST POOL PILOT and see if the results change.
    Low volts and low amps can indicate a blown fuse inside the unit or a failed power supply.
    JoshU's Avatar
    New Orleans, LA
    543
    As Jason mentioned having the unit in boost mode while testing is critical.
    How old is the controller?
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    I've tested in boost mode and got a slightly hight voltage reading (5-10v) and amps still less than 1. The controller is about 7 years old. Just looked up where the fuses are, I'll check them next.
    All fuses are good. Guess I need a new controller?
    JoshU's Avatar
    New Orleans, LA
    543
    If you call me I will run you through a few physical checks on the board to inspect the condition of things.
    Ok thanks. Just saw your post. Monday ok to call?
    JoshU's Avatar
    New Orleans, LA
    543
    Yes.
