Results 1 to 8 of 8
Thread: DE Filter Cleaning - 1st timer
    Feb 2014
    Phoenix, AZ
    51
    Hi Gang, Just completed the first 8 steps of the DE Filter Cleaning Tutorial, but running into questions :
    1. What would be a linky for the 'lube' ? Silicone based appears to be better - so maybe this or something like it. dont have any as I'm new to this and just want to be sure I'm getting the right stuff. There's probably a 6-way Vari-Flo valve tear-down in my future so I also would appreciate getting one thing I can use for all this.
    2. I dont see where I am supposed to fill the filter before I clamp the two parts together, but it seems like this could only reduce the amount of air that needs to get forced out of the lines and would therefore be a good thing. is it just unnecessary since there will always be lots of air to bleed so why bother adding water to the filter? or would adding in water actually be bad?
    3. The DE gets watered to make it a slurry, then dumped into the skimmer basket location slowly with the pump already running and having bled the air. Should I be at all worried about the DE getting out of the skimmer area and into the pool? Should I try to keep the little floaty thingy that doesnt let leaves come back out of the skimmer partially up to make sure the DE only goes down the suction line? just a little freaked out by the warning labels on the DE box and the chance of the DE just getting into the pool proper.
    and as a first time DE filter cleaner, please allow me to make a comment on the tutorial - which is mostly awesome and many thanks for it.
    Step 8. The location of the slot is as important for the bottom piece as the return pipe is for the top piece of the sandwich. and while the description is accurate if you know what you are doing, I think a picture can really help make the words clear. I've updated the image just above step 8 to include an arrow for the Slot that needs to be justified with the in feed pipe as well as the location of the 'short' grid both where it starts and where it stops.
    That was the only part I got wrong, but since I had already completely reassembled the filter and was trying to figure out why it wouldnt fit back into the shell, it wound up taking a bit of time dissasembling and then reassembling correctly.
    Much appreciated as always.
    Cardano
    20k IG PebbleTec w/ STA-RITE PE5E-182L 1HP and Zodiac Polaris PB4 for Polaris 380 vacuum / Hayward ProGrid DE4820 Filter / TF-100 but I havent broken down and gotten a speed stir yet
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: DE Filter Cleaning - 1st timer
    Quote Originally Posted by cardano View Post
    I just bought a tube of pool lube at the pool store. They had a basket full on the counter by the register. One tube is good for years.
    Don't bother. Once that pump primes, it will fill that filter so fast you won't believe it. After the first spurt of water out the bleed, close it up, give it a minute or two, and crack it again. Keep doing that until all the air works its way out the pump and filter. When you crack it and get no air at all, just water immediately, it's bled.
    Just go slow. The weir (flapper) should prevent backflow into the pool.
    38,475
    1. That looks like some good lube. I am almost out of what I have, so may look at that as well.
    2. I suppose you could add water, but not really needed ... it will always end up at least half full of air
    3. No concern about the DE entering the pool (not dangerous) ... it likely will not if you have all the suction going through the skimmer (you can not hold the weir up as that will starve the pump).
    The reassembly is a little tricky at first, thanks for the feedback. I will likely update it with your picture.
    Feb 2014
    Phoenix, AZ
    51
    Happy to help. Fresh eyes and a quick GIMP mod can make up for 999 words.
    weir = little floaty thingy that doesnt let leaves come back out of the skimmer
    word
    Thanks again.
    38,475
    I thought the picture with just the short grid standing there might be enough, but your picture does make it more clear ... I already updated the tutorial
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    What is the blue line, above the arrow for the "Short Grid 1st" comment, for? Is that really showing where the arrow should be? That inner vertical clip? Or does the short grid go right where the arrow is?
    Thanks for the update. I have the 6020 filter, just like the tutorial.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    38,475
    The curved line is the short grid, showing where it will sit ... the picture in Step 8 shows the actual grid sitting there.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Got it, thanks!
