Results 1 to 8 of 8
Thread: Greenish staining
    May 2014
    annapolis, maryland
    5
    Greenish staining
    Hi all,
    After having read a lot of posts about staining I decided to post my own pictures because I'm not sure which problem I have.
    The staining is greenish and doesn't come off when I brush. It's not scaling - the surface feels smooth.
    I opened the pool a week or so ago and got rid of the green water - the filters are doing it's job at clearing the water and the FC is good and steady. I'm putting a lot of shock in which is normal for me early in the season. My SWG is not running yet and I have not added salt.
    Before I venture in to an acid bath and brush the .... out of my pool I wanted to ask you smart people
    My pool is 5 years old.
    FC - 2
    CC - 1.6
    pH - 7.5
    TA - 78 (little low I know)
    CH - 360
    CYA - 55 (a little low also)
    Thank you!
    32K Gal, White plaster, AquaPure SWG, 4 x cartridge filters, LXi propane heater aka 'The cointhief' , Stealth 1,5HP pump, Polaris Robot aka 'Bob'
    38,290
    Re: Greenish staining
    Welcome to TFP!!!
    What test kit are you using? Your high CC points to a need to follow the SLAM Process.
    What "shock" product are you using? Be careful it is not adding too much CYA.
    Your TA is fine, leave it alone.
    You need to ID the stain. Try putting a trichlor tablet on it and see if it lightens in a few minutes ... that would be organic stains. Or try putting a vitamin C tablet on it and let is dissolve for awhile and see if that lightens the stain ... that would be metal staining.
    May 2014
    annapolis, maryland
    5
    Thank you.
    My test results are from the local pool store. But I also use test strips and my little Pentair pH and CL kit (twice a day) My TF100 XL test kit is on it's way in the mail.
    I have been using different shock products from Bioguard and Leslie's ... and latest Kmart - Clorox household bleach. But I have been careful not to use shock with CYA.
    I will try to put a trichlor tablet on it a see what happens and after that a vitamin c.
    Thank you!
    Jakob
    38,290
    I would not use any of the cal-hypo powder either since your CH is getting up there too. Stick with the liquid
    May 2014
    annapolis, maryland
    5
    Hi again,
    Just a quick update.
    I don't see any effect from the trichlor tablet or the vitamin C - I will leave them for a bit longer.
    I had the water tested again at the local pool store and I was surprised to see I had lost a lot of FC. The good thing is that the CC level showed low as well.
    FC - 0.1
    CC - 0.1
    pH - 7.5
    TA - 94
    CH - 362
    CYA - 55
    I just added 3gal of liquid chlorine (Sodium Hypochlorite) and I added salt so I can get the SWG going.
    Jakob
    38,290
    FC is consumed by the sun every day ... and I would not believe their test results anyway ... keep watching that mail box
    May 2014
    annapolis, maryland
    5
    Hi again,
    I left the trichlor tablet in the pool over night and the area around it cleared up. So it took at least 10 hours to show - regardless I guess I can assume by problem is organic.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,510
    You need to slam the pool. Look at my siggy below to find the link to the page (Shocking the pool).
    That will save you a lot of work!
