Thread: Pool circulation question regarding aiming returns
    rlefig's Avatar
    Apr 2013
    Reading, MA
    202
    Good morning, I have a Kidney shape pool, 16 x 32, with 8 ft maybe 9 deep end. As many of you might know from other posts this is my first summer with this pool. The pool has the its main drain plugged. The 2 returns and the 1 skimmer are all on one side. I return is in the shallow end, the other return is at the mid point of pool with the skimmer in the deep end.
    I have a question in what you would recommend for aiming returns. I had my returns pointed at surface of water and creating ripples around 3 ft out. After reading some other posts I changed it to have the shallow end return point mor downward almost parallel with top of water and to the end wall in the shallow end. I also aimed the mid point return down toward the center of deep end and a bit towards the deep end end wall.
    Picturtes might help,
    thoughts
    1971 Gunite 31x16 IG Kidney shape pool approx 18000 Gallons
    EcoFinish Blue Lagoon
    Sta-rite System3 S7M120 Cartridge Filter
    A.O. Smith 3/4 HP motor, starite pump
    TF100 test kit
    Re: Pool circulation question regarding aiming returns
    This kind of thing tends to require some fiddling. You want one return pointed down towards the bottom of the deep end, as you mentioned, and you also want to see a consistent water movement on the surface carrying debris to the skimmer. Try out different things and see how you do.
    One good way to check circulation is to empty a small bottle of food coloring into the water right next to a return jet and then watch to see how it circulates around the pool. You want to see the dye going everywhere in only a couple of minutes.
