Thread: D.e. Filter
    May 2014
    Danbury texas
    7
    D.e. Filter
    Will a d.e. Filter catch metals I have in the water or should I use metal out?
    Any other suggestions
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: D.e. Filter
    Is the pool cloudy with rust? Or is it just sort of tinted?
    If it's got chunks of precipitating iron making it cloudy likely the DE will catch some of it. If it's just tinted water, no. Either way, a sequestrant will be necessary. Have you read the pool school article on metals?
    Re: D.e. Filter
    Nothing will reliably remove metals from the water. Sequestrants will bind to metals and prevent them from scaling. Metals will sometimes clump together and get filtered out, but that is not really predictable.
    May 2014
    Danbury texas
    7
    Re: D.e. Filter
    I was just curious
    In the past the test shows metals then I put metal out then it will say 0 metals
    Richard320's Avatar
    Jan 2010
    18,967
    Re: D.e. Filter
    Quote Originally Posted by Randysmith112186 View Post
    I was just curious
    That's the way it's supposed to work.
    Metals are the chocolate. Sequestrants are the hard candy shell on an M&M. Do you see chocolate in a bag of M&Ms? No. But it's in there. Just wait for that shell to get dissolved and you'll find lots of chocolate in the bag. Hope that helps explain it.
    Jul 2007
    Hillsborough, NC
    520
    Re: D.e. Filter
    That's the best explanation of metals and sequestrants I've ever heard. I had a lot of problems my first 2 years with pools. Most of it was not ignorance so much as misunderstandings and bad explanations. I found two places that helped - this site and the folks that make the Jack's Magic products. I called them a few years ago to ask a question, the woman says "let me get you to one of our technical guys". It took a few minutes for me to realize that the Jack I was talking to was the owner - Jack himself. We talked for almost 45 minutes. As far as I am concerned, he has a customer for life. I'd go find the Jack's Magic product that is correct for your pool, and never look back.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
