Thread: Intex 12 by 24 pool ultra frame pool
    May 2014
    New York
    1
    I would like to add an electric heater as my kids spend more time in there when it is hotter- any ideas? I wanted to get a Hayward pump heater and 1HP pump/filter- will that work? The ultra frame uses 1.5" hoses and Hayward also does- first time posting- any advice greatly appreciated
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Intex 12 by 24 pool ultra frame pool
    Welcome to TFP! you will find this is the most informative pool site on the web.
    Electric heat? Are there no other options, such as natural gas or propane?
    You can use the Hayward system but you will have to either make some adapters to Intex fittings, or replace them with normal pool fittings.
    There are many threads here on the forums dealing with these.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Make sure you get a good solar cover too... It really helps with heat loss overnight...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Good luck. I want a heater for my 14x48 but the prices are absurd. Currently I am stuck with cold water even though I live in Florida.
    16x48 Intex Ultra Frame/ 1600 gph Pump sand filter SWG combo/ Ultra tools Widemouth Skimmer/ Using BBB method
    Casey's Avatar
    SW PA
    10,461
    snowcliff84, Does your pool get sun during the day? I have found that if I shut my pump/filter off and let the sun beat down on the water, it will warm it more evenly than using a solar cover. Then at night, I trap that heat by using the cover and taking it off again the next day, running the pump/filter for awhile and then shutting it off so the sun can do it's thing again. I gained 5 degrees in one day doing it like that.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Snowcliff84, I'm in Jacksonville and my water temp has been between 80 and 84 for over a week. What part of Florida are you in? I figured the whole state was warming up. Well at least it was till the mighty rain storm that swept thru today.
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
