Thread: Pool pump headache
    Pool pump headache
    Pool pump took a dump......now looking to replace
    Here's what I have.....27,000 gallons....1 big skimmer....2 returns....a slide....4 deck jets
    All piping 1 1/2 PVC
    Piping runs about 50 feet from skimmer to pump
    Catridge filtration and a furnace.
    What size pump should I look for? Like 2 speed I had because stayed on low speed unless kids used slide or for vacuuming.
    16x32 IG 20 " sand filter
    Raypac gas heater
    1hp certkin pump
    Abrisud telescopic hard swim under cover
    38,301
    Re: Pool pump headache
    Probably similar to what you had if the flow rate seemed appropriate for your equipment.
    Although I am not sure what kind of pump you had. HP is only half the story, for example Superflo is a smaller pump than the Whisperflo even at the same HP.
    30,421
    I know you didn't ask but it is pretty significant to match your filter to the size of the pool and then match your pump to the size of your filter.
    A 20" sand filter in that pool is really too small. I'm guessing just a bit but a 24" is probably OK with a 30" being great!
    If you can swing that upgrade, it will perhaps change the size of your pump we suggest.
