Thread: cyanuric acid vs Isocyanuric acid
    Can anyone tell me the difference between these two acids? The Isocyanuric acid is sold at Menards. It's cheaper than Leslie's acid.
    Their MSDS shows:
    1,3,5 Triazine-2,4,6 (1H, 3H, 5H)-trione
    (Isocyanuric acid)(CAS #108-80-5)
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: cyanuric acid vs Isocyanuric acid
    That's just the IUPAC name for cyanuric acid so there's no difference between them. Get whatever is cheaper so long as the concentration is the same. Just be a little careful in that some brands that came from China have been found to not have pure CYA in them, but it's been a while since I've heard about such problems.
    If the product from Menards is 100 % and for pools, it's ok to use. Isocyanuric acid is just another name for cyanuric acid.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Other names for Cyanuric acid are:
    1,3,5-Triazinetriol; s-Triazinetriol; 1,3,5-Triazine-2,4,6(1H,3H,5H)-trione; s-Triazinetrione; Tricarbimide; Isocyanuric acid; Seudocyanuric acid (Thank you wikipedia)
    I think they do that so you can't see that you're getting the exact same chemical for less somewhere else.
