Thread: Draining Pool Question
    Due to my high CYA levels (100+) I am doing a partial drain of my pool. Currently, I have a hose attached to a faucet bib near the pool pump to drain. Slow going but plan to rent a pump at home depot. Just wondering, is there an issue running the pool pump with the return outlets not being submerged in water? I currently have the water running through the pump on the main drain that is located on bottom of the pool. I have shut off valves through the cleaner and skimmer.
    THanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: Draining Pool Question
    No. You're doing it perfectly.
