Results 1 to 10 of 10
Thread: So Now That My Beaded Liner Is Reinstalled...
    Jul 2007
    Hillsborough, NC
    525
    is there something I can get that I can put in the bead to keep the liner in place? I could probably make wedges out of PVC but I imagine for what I'd pay for something it isn't worth my time to make it.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Casey's Avatar
    SW PA
    10,444
    Re: So Now That My Beaded Liner Is Reinstalled...
    I've heard pennies work like a charm.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,089
    Do a search for Liner Lock. It clips into the track to hold the liner. You can find it at most pool stores. Very simple to use.
    Jul 2007
    Hillsborough, NC
    525
    I will look for liner lock. I tried pennies tonight, they fell into the pool.
    I did some checking, as it turns out I have a j-hook liner, not beaded. Will liner lock still work for the j hook liners?
    Casey's Avatar
    SW PA
    10,444
    J hooks hang over the side of the pool. I have that kind of liner and I could have turned it into a bead by cutting the J hook off.
    Jul 2007
    Hillsborough, NC
    525
    This is what I have
    Casey's Avatar
    SW PA
    10,444
    That is a beaded liner. The J Hook hangs over the wall. When I bought my liner, I could use it either way. I was going to use the track and go with the bead but decided not to. I would have had to cut the J Hook off. Did you install the pool and liner yourself? If so, did you cut the J Hook off the liner?
    Jul 2007
    Hillsborough, NC
    525
    Yes I installed it myself and no I did not cut the j-hook off the liner. My liner is installed exactly like the picture. I don't have the directions any more but I am pretty sure I followed the instructions that came with the liner. I looked here for an old thread I might have posted about it but couldn't find one.
    Casey's Avatar
    SW PA
    10,444
    If your liner looks just like that, it's a beaded liner and not a J Hook.
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
