Results 1 to 7 of 7
Thread: Pool Cover on or off during day?
    May 2014
    Bay Area, California
    13
    Hi,
    I have a dark blue vinyl pool cover that is on the pool at night. (electrically operated, so easy to open and close).
    The pool is in-ground about 20x40.
    The question is if it is a hot day outside (90 degrees plus) should I have that cover on or off if I want to heat the pool?
    On the one hand, when it is on during the day and then I later open the pool, you can feel that the first several inches of water is very hot from the cover.
    On the other hand, it seems that if the pool were open that it would be heated directly by the sun.
    I know there is evaporation if I keep it open and chlorine used up, but I am mainly concerned with heating the pool.
    Thanks
    Casey's Avatar
    SW PA
    10,461
    Re: Pool Cover on or off during day?
    Hello and welcome to TFP!
    I have stopped using my cover during the day recently because it only heats the top ft of water and the bottom is cold! I've found that the sun heats my pool a lot better if I leave my pump off and just let the sun have at it! It's even heat too, all the way to the floor. If I want to retain that heat, I would cover the pool at night as to not lose it to evaporation.
    It would be helpful if you add your pool specs to your signature. Go to settings and on the left, select Signature and add to the box, click save.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !
    I agree with Casey. You'll get a lot better heating with the cover off during a nice warm sunny day and retain the heat with the cover on at night.
    Jeff
    Apr 2013
    Westside LA, CA
    49
    and... your cover will last longer without the sun blasting on it.
    May 2014
    13
    Thanks everyone!
    I have only had this pool for 10 years before I figured realized that it would be better with the cover off
    Although my excuse is that earlier, our kids were young, so there was a real benefit for having the cover on all day...and we do have solar, so that got the temp where I wanted it...eventually.
    35,000 Gallons, in Ground with a pool cover.
    Pebble-tech with Hayward DE Filter (about 54 sq ft), using fiberfill instead of DE.
    Hayward 1.5 pump, single speed
    About 10 years old.
    Hot Tub, Solar Heating, Gas Heating.
    wmwinn's Avatar
    Jul 2012
    Albuquerque, NM
    27
    Depends on your humidity. I live in the high dessert of Albuquerque, and water evaporation is a cooling process. My water always gets cooler with the cover off... And cools even more if there's wind.
    Inground gunite 34x28 sport pool (24,300 gal)
    Hayward T-Cell-15 SWG, Solar heating
    Hayward sand filter, automatic cover
    Muriatic acid injection using fish tank peristaltic pump
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Quote Originally Posted by wmwinn View Post
    Sent from my Nexus 7 using Tapatalk
    That's the $64K question. Humidity and wind. They can make it of questionable value being open even on a sunny warm day. So in addition to your location, it's a matter of what weather front has just passed through your area.
    But I do agree, humid and/or calm and sunny then open it up to warm the pool. My pool same size, with a deep end, heated up over 6 degrees, from 68 to 74 on a very sunny, humid 87 degree day last weekend...one day. Obviously the pool temp was way below the mean temp for the day so that helped make the rise so big. Then cover that sucker up at sundown.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
