Page 1 of 4 1234 LastLast
Results 1 to 20 of 78
Thread: TF100 Test Kit - First Result
    May 2014
    Ohio
    75
    I just opened my pool yesterday, mesh cover, and vacuumed the junk to waste. Mostly worms. Pool is cloudy, I can barely see the main drain in deep end. Water was high, almost to edge of liner. Is that why TA is so low?
    FC 2.5
    CC 2.5
    TC 5
    CH 150 ppm (How blue is blue?)
    TA 180
    CYA 70ish??
    Anything seem odd? What's the newb's next step?
    Thanks
    16' x 32' Hopper IG Vinyl | 19,000 Gal | Pentair Tegalus 60 Sand Filter | Pentair Challenger 3/4 hp Pump
    38,532
    Re: TF100 Test Kit - First Result
    What makes you think a TA of 180ppm is low? That is pretty high.
    What is the pH?
    Since the pool is not clear, you need to follow the SLAM Process. You CYA is a bit high and the SLAM would be a little easier if you replace some of the water, but this is not required at this point.
    All the tests are done until the last drop does not cause a color change (and don't count the last drop).
    May 2014
    Ohio
    75
    Sorry, meant the CH is low.
    May 2014
    Ohio
    75
    pH is between 7.2-7.5
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If your PH is close to 7.2 then your good to go with that. The lower PH makes the chlorine more effective for the SLAM process.
    Make sure you review the SLAM process and follow it to the T.
    The lowering of CYA is your call. It will make the SLAM easier by using less bleach to reach the SLAM level. Also a lower CYA will make keeping your FC in range for the CYA level when the SLAM is done easier.
    How have you been chlorinating your pool ?
    Jeff
    May 2014
    Ohio
    75
    I had one bag of smart shock left over from last year and added a gallon of liquid chlorine. Last year, smart shock and 3 inch sticks.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Ok. This year your not going to be using powdered shock or chlorine sticks. Your going to switch over to liquid chlorine. You won't have any bad side effects form bleach like you will from the pool store chem's.
    With all that said let's get focused on SLAMming the pool and get that over with. Then we can get you set up with chlorinating your pool the TFPC way.
    When you have questions don't hesitate to ask ! 😎
    Jeff
    May 2014
    Ohio
    75
    How long should I wait after adding chlorine for the SLAM to test FC?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You can test after 30 min's. Make sure pump is running to mix chlorine.
    Jeff
    May 2014
    Ohio
    75
    I added 4 gallons of 12.5% chlorine. It only raised my FC from 2.5 to 4????
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Maybe your pool volume is off or the chlorine isn't 12.5% anymore and could be a little less than 12.5%.
    Jeff
    38,532
    What are your CC results?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    How blue is blue - like a powdered light blue, with a slight pale lavender tone. Purple endpoint is something different - see the extended test kit directions in Pool School.
    May 2014
    Ohio
    75
    Last test, convinced the bleach is junk.
    FC 4.0
    CC 15??
    38,532
    With high CC, seems like you may be another victim of ammonia in the water. Just keep adding bleach until the FC starts to hold and CC drop.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yep if it's ammonia it will consume your chlorine very quickly.
    Jeff
    May 2014
    Ohio
    75
    My AM reading.
    FC 1.5
    CC 4.5
    Off to the store to get more bleach.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Keep dumping the bleach to it ! It's going to eat up the chlorine quickly till the CC's come down. 😎
    Jeff
    May 2014
    Ohio
    75
    Any guesses on how many gallons to add? Cloudy, rainy day so I'm gonna hit it at lunchtime.
  20. Back To Top    #20
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    What ever the amount is to get it to SLAM level or a little higher. Use pool math. 😎
    Jeff
