Thread: AutoPilot Digital Blowing Fuses
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Bad lightning storm last night. AutoPilot digital was dead today. Fuse on the lower left of the unit was blown. Replaced it. Worked for a bit...long enough for me to think I fixed it, close it up, and walk away. An hour later that same fuse is blown.
    Before I call pool builder for service, is there anything else I should check/try? Unit is less than 1 year old.
    Thanks.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    Re: AutoPilot Digital Blowing Fuses
    It is unlikely, but I would check for debris in the cell that could be shorting out the cell plates.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    No debris in the cell. I'll see if I can get another new fuse in there later tonight.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    New fuse blew in 5 seconds. Called pool builder...waiting for return call from their "electrical guy."
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Fried controller relay...controlling power to the Auto Pilot. When relay is bypassed...all seems to work fine.
