Results 1 to 7 of 7
Thread: Need Help & Opinions Please - Ready for collar, pool not perfectly square
    wanjayne's Avatar
    Jun 2012
    Wichita, KS
    26
    Hubby has everything staked and we're spot on as far as being level; However, when measuring from corner to corner today, measurement shows 4" off!!! Hubby is a perfectionist and we've measured seam to seam on sides and ends.. each measurement is spot on 36' & 18'! Checking for level reflects level to within 1/16"! Needless to say, this is making us both NUTS! If we unbolted and moved stuff, I can't imagine it would turn out right. We have concrete coming in Friday to pour collar.
    Would love to hear thoughts and suggestions. How much variance in "squareness" is acceptable for good liner fit???
    Thanks, Jan
    Coming in Spring 2014: Semi DIY 18'x36' rectangular 2' radius ig steel wall vinyl; 3.5'-8'; NO main drain, 2 skimmers, dedicated cleaner line, 5 returns (2 surface, 1 low in deep end, 2 in steps,); 1hp Pentair Whisperflo 2-speed pump; Pentair Clean & Clear 420 cartridge filter; Intellichlor IC40 swg; Raypak Digital NG 399K Heater; (2) Pentair Intellibrite LEDs, 2 wheel Poolvergvegen ; S.R. Smith Salt System diving board
    38,429
    Re: Need Help & Opinions Please - Ready for collar, pool not perfectly square
    I would think you want it pretty close to square. So, you have rhomboid and not a rectangle right? Your corners are not 90 degrees.
    Disclaimer, I have never dealt with these pools before: You may be able to just push in on the long diagonal a bit ... if each of those corners moved in an inch, the other corners should move out an inch and then match.
    wanjayne's Avatar
    Jun 2012
    Wichita, KS
    26
    Apparently so, Jason!... Glad you included the link.. I was thinking "what do my joints have to do with it"... LOL!!! Anyway, it just sucks to think we've got it right, then put corners & steps in & find out we're off. I just hope the last portion on the end (steps) is all we have to tweak to get it square. Anyone else have this issue before pouring collar?
    30,431
    I am assuming you are measuring the diagonals which means you are 2" out of square. That's not too drastic but it is something that might bug me....especially if I was 1/16 out of level.....wow!, that's good.
    It's an easy fix in one respect. All you have to do is take one corner of the longest diagonal and move it 2" toward the center. That should make it less than an inch out of square and perfectly acceptable and unnoticeable.
    That said, moving that one side may screw up your level and make it not worth it. Level is by far more important. I think I would be tempted to leave it unless you are going to have a decking out of tile.
    wanjayne's Avatar
    Jun 2012
    Wichita, KS
    26
    Dave - You just made us feel a whole lot better... Thanks! We were thinking we would have to take one whole side apart & move it. Decking will be concrete. Visually, at this point anyway, I don't see anything that would make me think it's not square; however that said, if we leave it as is, will we have issues with the liner?
    wanjayne's Avatar
    Jun 2012
    Wichita, KS
    26
    DH adjusted walls and now we're square to within 1/4". Level is within 1/4" as well. WOO-HOO!!! Thanks for all the help!
    Jan
    38,429
    Nice job
