Results 1 to 8 of 8
Thread: Filter grid replacement
    Mar 2013
    Springfield PA
    11
    I have a KDI DE filter 48 SQ FT Model NO. 584090, Length 22 IN, Width 22 IN, Height 52 IN. I cleaned the grids last season and during the process noticed they were not in good shape. I am considering replacing them all including both manifolds and was wondering if the grids/manifolds are generic for all 48SQ FT filters or I have to look for specific ones to fit. Any guidance or recommendations will be greatly appreciated.
    IG Plaster 28,920 Gallons. KDI American DE Filter 48 SQ FT (Model 584090). AO Smith SQ1072 Pool Pump Motor 3/4 HP. Polaris F9300 Sport. TF-100 test kit.
    38,301
    Re: Filter grid replacement
    I am not sure what the KDI filter is ... I do think the Pentair and Hayward grids are interchangeable. The Unicel that I bought as replacements I think said it could be used in either of the manufacturer's filters.
    Mar 2013
    Springfield PA
    11
    There is a sticker on it that says "KDI AMERICAN DIATOMACEOUS EARTH FILTER". Somewhere off the sticker it says American Products.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    One of those old stainless steel jobs!
    Good news for you. I used the search box: http://www.troublefreepool.com/threa...-filter-models Post 10 -13 should help..
    Mar 2013
    Springfield PA
    11
    I went ahead and ordered a complete set from poolplaza (American Titan CM or S/S 48 sq. ft. Grid Assembly (Grids24 inches tall)(59002500) use(59023400) ). I ordered it yesterday afternoon and it was here at 10:30am. Free shipping and excellent service. It fit just right but my pressure is quite low 5 Psi. Will check on it later to see if it rises because I put 6Pounds of DE and replaced pressure relief valve as well.
    Eddie
    38,301
    Low pressure is not necessarily a bad thing.
    Mar 2013
    Springfield PA
    11
    Always something new to learn. I always assumed starting pressure had to be > 10psi. The old broken filter actually started with 17 Psi last year and this year.
    38,301
    With the lower pressure (resistance through the filter) your flow rate should feel higher. As long as the flow is good, don't sweat it
    When mine runs on low speed, the pressure barely registers as 2psi.
