Thread: Need help with New water and Test Results
    Hello all,
    I just drained and refilled my pool. I have the taylor test kit but couldn't get a reading for CYA and FC. Am I to assume there is no CYA and FC? Just wanted to be sure before I add the CYA.
    FC-
    CC-
    pH-8
    TA-210
    CH-170
    CYA-
    I added about one gallon of muriatic acid to lower the pH and TA last night. I need to go get more chemicals...muriatic acid, cya, liquid chlorine. What should I get for raising CH?
    Thanks
    40' x 17' Kidney shaped / 26,000 gallons / Plaster/ DE Filter
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    Re: Need help with New water and Test Results
    Fill water might have a tiny amount of FC but would not normally have CYA, so I think your assumption is good.
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    If the FC test does not turn pink at all, the FC is zero.
    If the CYA test is completely clear, even when you fill the view tube, then CYA is zero.
    The first thing to do is to lower PH to 7.2, then start adding some CYA.
    Add 2 ppm of chlorine this evening after dusk and each day until you add CYA, and then 24 hours after you add CYA switch to raising FC to your target level based on your CYA target level.
    Thanks guys! I'll be adding CYA tonight and then chlorine.
    What about the CH. Do I need to worry about that now? Will adding any of the chemicals to raise CH affect other factors? Just want to know if I should consider CH when trying to balance the other levels.
    Thanks
