Thread: Adding boric acid
    Adding boric acid
    ok just to be certain, what I ordered is granular boric acid white crystals 99.9 % pure. This is the right stuff yes?? I actually ordered 2 25 lb bags.
    23k gal IG Vinyl Liner
    Sand Filter Pentair Pump VS
    Electric Heat Ft Wayne Indiana
    Built 2012
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Adding Borates!
    Yes, that is the right stuff and the granular is better to use than the powdered since powder tends to sit on the surface of the water. I just added some granular to my pool to get the borates back up to 50 ppm and it almost all sinks and it dissolves quickly with just a little sweeping needed.
    Re: Adding Borates!
    Quote Originally Posted by chem geek View Post
    Thanks!!
    Built 2012
    Re: Adding Borates!
    I am hoping to add my boric acid tomoorow. Could someone tell me exactly where my TA and PH need to be BEFORE I add. I read back thru the thread on borates but not sure if the same rules apply when your using boric acid vs muratic acid and borates.
    Built 2012
    Re: Adding Borates!
    PH can be anywhere in the normal range. 7.5 to 7.8 is fine.
    It is good to have TA down near the low end of the range, say 60 or perhaps 70, though this is not absolutely essential.
    susa's Avatar
    Oct 2010
    Deep South
    578
    Re: Adding boric acid
    This is what I have also ordered from amazon, the 25 LB version, works very well
