Thread: Backfilling the trenches and around the Pool
    Apr 2014
    Enola, PA
    24
    Thanks to all the Nice and knowledgeable people on this forum, I have kept myself sane thru this process. We decided to contract out the decking portion separately from the Pool Builder. Our Landscaper has been working at this property and at my neighbors for a long time and he maintains all the irrigation system, outdoor lighting etc etc. Our Pool Builder is insisting that filling up the trenches, back filling around the pool, and Basin (6x5x2) that they had dug for gunite people (which they did not use) is the decking guys responsibility. The decking guy is refusing to accept that. He says that the PB has to rough grade and clean up their mess.
    We (as in I) are caught in the middle. So my question to you’ll is -- generally who is responsible for it? In this scenario who is being unreasonable.
    I am concerned that if we have a crack or some leak or something the Pool guys might come back and say that decking guy messed it up ..
    I am so stressed right now ..
    If you can tell me how to upload pictures I can upload some pictures of what I have on my hands..
    Re: Backfilling the trenches and around the Pool
    I would tend to agree with your decking contractor - the pool builder should backfill and perform a rough grade. I know ours did and we are not using the PB for our decking.
    Nov 2013
    Miami, FL
    348
    I believe the PB SHOULD be responsible for backfill and rough grade, but I would check your contract. Do you require a permit and inspections? If yes, maybe contact the county/city permitting department to get some guidance.
    Swimming!: 19x32 IG rectangular pool, 22,500 gallons; 3' - 6.5'; open spa w/ 6 jets; raised wall w/ 1 sheer descent and 2 minijets, 2 color-changing LED pool lights, 1 spa light; Jandy 2 1/2 HP 2 speed Pump, Jandy cartridge filter (320 SQFT), Diamondbrite Cool Blue
    Jul 2013
    Clarksburg, MD
    93
    Since you are using AS I will chime in.....AS told me that the pool quote included backfill and rough grade, however the person doing this is the pool deck crew, so in essence it is the responsibility of the decking folks to back fill and grade....just so happens I put the decking under contract with AS which is why it's all covered in my build.
    Just my 2 cents.
    18k gallon IG Sunstone Pearl pebble finish pool, Jandy Aquapure 1400 SWG, Jandy 1.5HP VS E-Pump, Jandy 60sqft DE filter, Jandy Legacy Propane Heater, Polaris 3900 Robotic Cleaner, TF-100 w/ SpeedStir, Anchor Mesh pool cover
    Apr 2014
    Enola, PA
    24
    Happy to update that after the a little back and forth the PB is back filling the trenches and rough grading.
