Thread: Need Hayward Filter Valve part number
    I have a Hayward Pro Series S244SV sand filter with a 2 position slide valve. I broke the handle off the valve and need to replace the whole handle/plunger assembly. I see a few different versions online, and I'm not sure which I need. My valve has SP-410-C on the side.
    15000 Gallon PebbleTec w/ spa, 1.5hp single speed pump, Hayward S244S sand filter, A&A in-floor cleaning
    38,301
    Re: Need Hayward Filter Valve part number
    Here is the manual that lists a part number for one of the plunger backwash valves.
    http://www.hayward-pool.com/pdf/manu...0sv-s244sv.pdf
    Or you could upgrade to a multi-valve.
    Here is a nice chart comparison with part numbers as well:
    http://www.poolplaza.com/C-V-BW-HW.html
    Thanks... Found it.
