Thread: cya and covered pool
    Jun 2013
    Indiana
    57
    Was wondering if I could keep my cya level lower than the typical recommended level if my pool is covered the majority of the time with an automatic pool cover. I thought with less sun maybe there was less need for cya. No SWG, just use liquid chlorine. Current cya level is about 20.
    Mark
    IG plaster, 22,000 gallon, Jacuzzi Laser Sand filter
    Re: cya and covered pool
    If the pool is covered essentially all of the time, yes it is reasonable to keep the CYA level a little lower than normal. I suggest a level around 30, though anything from 20 to 50 is fine.
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    I keep mine lower but not quite *that* low.
    My CYA hangs around 50-55 cause I have a SWG. The recommendation is more along the lines of 70 with a SWG.
    Oct 2013
    Iowa
    82
    As an owner of a pool with an autocover I've had the same thoughts. However while the pool is in use/open the need for CYA isn't any different than a pool without an autocover so I can't personally see going below 30. Most of the time if we have people in the pool the pool is open and in full sun all afternoon.
    Unfortunately my first opening of the new to me pool last year had CYA well over 200 and I gave up after getting it to 70 and used it at that level, this year I'm down to 45, but mainly because of the autocover I'm planning to work down to 30 eventually, although if I have to raise the FC noticeably higher than normal just to last a full day of being open I will keep CYA higher. I figure if I maintain it at 30 I can only use 4-6 pucks a year, which will make that 40lb tub I bought before the first opening and before I knew better last over a decade...
    20,000gal in-ground 16x36 sentry pools vinyl liner, Pentair sand filter, Pentair minimax NT heater, auto-cover, Polaris 280 cleaner.
    Mar 2007
    San Rafael, CA USA
    12,082
    I have a mostly opaque automatic pool cover and the pool is used almost every day for an hour or so. I used to maintain 30 ppm, but eventually decided on 40 ppm as a reasonably sweet spot going between 3 and 6 ppm FC only dosing about twice a week. We keep our water warm at around 88F which leads to a somewhat higher chlorine loss though due to the cover it's less than 1 ppm FC per day.
