Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Hello! New to Forum and have a unique problem
    May 2014
    San Diego, CA
    35
    Smile Hello! New to Forum and have a unique problem
    Hello everyone... I've been lurking around this site for a couple months now, and have finally decided to make a post.
    First some background. We purchased our house last June, and it was a flip... The house was built in 1970, and obviously the pool added sometime after that, but I don't have any knowledge of the actual age of the pool. It's a organic shaped pool which I estimate around 10,000 gallons, and as part of the house flip the flipper "remodeled" the pool by giving it a good scrub and painting it. They obviously didn't care to much about the chemical makeup of the water considering it is completely jacked up as I will get to in a minute.
    One thing about the painted surface of the pool is they never used any non-slip additive to the paint, so the steps and floor are very slippery. I promised my wife that when we got the opportunity we could get some non-slip coating added.
    Now... on to the chemistry of the pool. The CYA level is 150+ the CH is 400, and I can't maintain FC levels above 1 for more than 3 days at a time. I made the mistake of going to Leslie and letting them convince me to buy about $200 in chemicals... but I am done with them after they told me conflicting things within about 2 days of each other.
    I have decided the best move forward is to completely drain the pool, and since the water is out give the thing a good scrub, and repaint with anti-slip additive. Considering this is the first pool I have ever dealt with, my first questions are essentially how do I completely drain my pool (my waste pipe is capped off on my filter) and what is the best advice on painting the pool surface?
    Here is a picture of my pool pump/filter which I think or circa 1980 :P
    I have been studying the pool school methods for maintaining water, and feel confident I can maintain the water myself once I get the pool back up.
    Oh... One last thing... I'm also trying to plan, and organize all of this work from about 2000 miles away from my pool LOL. I'm away from home for a month due to the Military and can't do any of this work until I get home, so I am trying to plan and organize my attack so I can get it right the first time.
    Any advice is definitely appreciated.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Hello! New to Forum and have a unique problem
    Welcome!
    Sorry, you're not unique. Lousy work by inept contractors and erroneous information and advice from pool store employees are fairly common around here.
    Unless your pool is plumbed with a dedicated line to the main drain (it doesn't look like it), you won't be able to use the pool pump to drain. Just rent or buy a sump pump. and be done with it.
    The backwash port on your pool shouldn't need to be capped. That metal rod underneath is your backwash valve. Sometimes whatever it is inside doesn't seat right and it drips. I find that moving it back and forth a few times after everything is cleaned will usually get it to stop.
    May 2014
    San Diego, CA
    35
    Thank you for the reply Richard... You are right... I have one skimmer and one main drain that are tied into the same return line to the filter. Is it possible to use a diverter to force the water to come from the main drain and not the skimmer? or will this cause air to enter the system regardless of the seal on the diverter?
    Richard320's Avatar
    Jan 2010
    18,995
    You'll suck air, guaranteed. If you fumbled around you might be able to fabricate some kind of U with O-ring seals that would connect the two ports, but a cheap submersible pump would likely be cheaper and the pool could be empty by the time you're done fussing around building an airtight loop.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    You could plug the hole in the bottom of the skimmer with an expandable rubber plug. Like this: Expandable rubber plug
    That way all the suction would be directed at the floor drain. Experts may or may not agree with doing this.
    Isolated Spa - 345 Gallons
    Richard320's Avatar
    Jan 2010
    18,995
    Quote Originally Posted by JVTrain View Post
    All that would do is block all the suction or block the line to the floor drain. You must be one of the fortunate ones whose main drain has a dedicated line.
    Feb 2014
    Central Minnesota
    5,080
    Yep, dedicated main drain here.
    Guess that's not an option interpim. Sorry.
    May 2014
    San Diego, CA
    35
    I think I'm going to have to go with the sump pump... my main drain feeds into my skimmer and suction is taken at the skimmer... the only way to prevent air from entering the system would be to build a air-tight loop like Richard mentioned.
    Does anyone have any recommendations on the process of painting? As in best way to prep an already painted surface and brand of products I should use?
    soupy8728's Avatar
    Sep 2012
    Temecula, CA
    66
    Where at in San Diego are you? I'm up in Temecula. I've followed the advice of the experts on here and have a fabulous pool to show for it. Let me know if you need any help with your water once you refill.
    ~Carl
    IG Plaster with raised spill-over Spa, ~26,000 gallons, Built 2001
    Cartridge filter
    Solar heated
    May 2014
    San Diego, CA
    35
    I'm in the East County portion of San Diego Carl... And from the looks of your avatar pic you do have a fabulous pool!
    soupy8728's Avatar
    Sep 2012
    Temecula, CA
    66
    I used to live in Santee and El Cajon/Rancho San Diego. Shoot me a PM if you want to trade numbers and we can talk pool school. LOL!! Yes, that's my pool in my avatar....she is a beauty.
    ~Carl
    Cartridge filter
    Solar heated
    Feb 2014
    Central Minnesota
    5,080
    There are number of threads on the site discussing pool paint. Search for "pool paint" in the search box and there's quite a bit of info.
    Getting the details of your pool in your forum signature would help the experts here and help you gather specifics on your pool and equipment.
    Oct 2013
    Chapin, SC
    1,141
    Quote Originally Posted by interpim View Post
    Thank you for your service from a vet in SC! Good luck with your pool!
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    May 2014
    San Diego, CA
    35
    Thanks for the offer to chat Carl... It would be nice to speak with someone that knows what they are talking about and isn't trying to get me to buy something. I'm unable to chat for a while though because of being in Central America for a little while... As far as Santee, I actually live near Santana High School!
    JVTrain, Thanks for the advice, and I am honestly not sure what to put down in my signature, as I am not sure exactly what I have :/
    I know my pump is a single speed Pentair pump, but the filter is so old I have no idea what it is besides DE. As far as the pool itself, I am guessing that it is a gunite inground pool with about 10,000 gallons based on the organic shape.
    soupy8728's Avatar
    Sep 2012
    Temecula, CA
    66
    No worries...just PM me when you get back and we will check it out!
    Cartridge filter
    Solar heated
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi Interpim,
    Welcome.
    I noticed in your initial post that you mention you cant maintain FC above 1 due to CYA of +150. It is of huge importance to be able to maintain FC at a level so as to keep algae at arms length and your pool seems to be in the high risk category for an algae attack.
    If you've read very much here, you know we put a lot of stock in using a proper test kit in order to determine what "is" and what to do aboiut it.
    Do you have someone who can test and maintain your pool while you're away from home?
    Would it be possible for someone to assist to getting a recommended test kit and test, so we can help with regards to keeping your pool chemistry on the up and up?
    Or is the plan to just let it go for now and drain, repaint and start over?
    Divin Dave,
    May 2014
    San Diego, CA
    35
    I hate to say that I am "letting it go" but, when it boils down to it, that's whats going to happen.
    My wife is home and I have her testing it with some cheap strips just to get a good idea where the chlorine is and adding a bag of hypo chloride when she gets a low reading... I am just having her do that until I get home, and then the plan is to completely drain, repaint and start from scratch.
    My water is to far gone to try and maintain it as it sits. I have been looking at the kits, and I am planning on buying the TF100 kit. I'll probably order it a week or two before I return so it will be there when I get back home.
    At that point I can start at a good baseline, and maintain the pool properly now that I have found this place!
    ~10,000 gallon IG painted plaster free-form pool w/ 1 skimmer and 1 main drain
    Intelliflo 3hp vs pump
    Pentair C/C 420 cartridge filter
    TF100 test kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Touching on the CYA 150+ and the FC of 1 - that could totally explain the slippery-ness. Are you sure you need to repaint?
    May 2014
    San Diego, CA
    35
    There are a few spots around the pool that need some patchwork done, so I figured I could knock it all out at once... fix the water, patch the holes, repaint, and refill.
    TF100 test kit
  20. Back To Top    #20
    Jul 2011
    N. Ga Mountains
    151
    Thought I would mention that when I first got my pool 5 yrs ago we had to drain it and move it in 1 day...long story. Anyway we rented a pump at Home Depot for 40.00. In 2 1/2 hrs the pool was totally drained. Well worth the 40.00!
    33 ft round x 52", vinyl
    Hayward 1.5 hp pump
    sta-rite 2.18ft ,200 lb sand filter
    24500 gal.
    Hayward Salt & Swim3
