Thread: Mustang 56 Frame pool pump by Waterway leaking
    Pump was leaking so I replaced part 5 (face plate o-ring) because that is where the leak was coming. However now the leak is coming from under the pump where the motor(1) meets the faceplate(4). I am not sure if I am not getting it back together correctly. I tighten all the screws and lubricate gaskets. Could it now be my shaft seal or something else?
    Thanks Danea
    Pool is 20K, sand, IG, vinyl, fiberglass, polaris 360 cleaner. I live in New Jersey.
    Casey's Avatar
    SW PA
    10,446
    Re: Mustang 56 Frame pool pump by Waterway leaking
    Smykowski's Avatar
    Sep 2011
    3,065
    Can you post a picture? Usually leaks like that are a bad shaft seal.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Anything ever come of this? I'm 99% sure I need a new shaft seal. I have the same pump.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
