Thread: Skimmer Splash
    Jun 2008
    North Carolina
    38
    Skimmer Splash
    Even when the water level in the pool is just above the return jet we seem to be splashing a lot of water out from the top of the skimmer. We are not concerned with the water loss except for where the water is going. Right now it is settling around the filter and pump even though we have slanted the ground there. Our concern is that we wanted to put a deck around the pool with plans for a little house around the skimmer, pump and filter. As I dreamed about this last night I realized that all that water we splash our would then sit in the bottom of the little house. Any thoughts on this? Does anyone else have this problem with water splashing out fairly often? Thanks for the help!
    Round 24' AGP
    13,500 gallons of cold water
    Sand filter
    BBB
    North Carolina
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Skimmer Splash
    Yes, when the kids are particularly active.....
    When you say "house" what do you mean? Will it have a roof? Wouldn't having a shield of some sort mean the water would be diverted? Is your filter raised up on blocks? Mine sits on 3 inch thick 18" square concrete blocks, surrounded by rocks, so the water pretty much drains away.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Re: Skimmer Splash
    We get a lot of splash from the skimmer when the dogs do their belly flopping. Our deck is built around the pool with the skimmer under the deck but accessible from the deck. Take a look at our pool pages in the link in my sig line, maybe it'll give you some ideas that'll work on your 'dream house'.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Rockcrawler's Avatar
    El Paso, Texas
    174
    Re: Skimmer Splash
    Water coming out of the top of the skimmer is normal,If water didn't come out of the skimmer top, wouldn't you still have to worry about rain run off as well???
    13,000 IG Plaster, 2hp whisperflo pump, 48 sq in pentair DE Filter, 1 skimmer, 2 eyeball outlets, 200 sq ft solar panels on second story, Auto Pilot SWG-36, Polaris ATV Cleaner
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Re: Skimmer Splash
    Mine does the same- My pool is about 1/2-1 inch higher on that end than the rest of the pool So when I add a litte more water than half way up the skimmer, I notice a lot of splash out.
    We are thinking about a "little house" for our pump and filter as well. But I was concerned about spiders and such moving in.
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Crazycalvin's Avatar
    Mar 2008
    Irmo, South Carolina
    56
    Re: Skimmer Splash
    Hello. Our pool is level and so is our skid pack area. We dug a french drain to let water run from the equipment area. We then covered the area with drainage rocks. It works well for us. Hope this helps. Later, Calvin.
    15 x 26 Sharkline
    2.5 HP Dual Speed Pump
    200 Sq. Ft. cartridge filter
