Thread: Foam Bottom
    Jun 2013
    Middlesex County/VA
    50
    Foam Bottom
    I had my pool installed a little under two weeks and have noticed the there are two to three areas where the 1 inch foam underlayment is gaped by approximately 1/2inch. All the dirt is settling in those areas, which is nice and easy for vacuuming however concerned about damage the liner may endure. Am I stressing over nothing. I have contacted the installer and he said he could not quaranteed absolute smooth bottom and that separation could occur. I sure hope I here ok news because that would be expensive 600.00 more dollars of water shipped in.
    Pool Size: 24' Lomart Whispering Wind II 13000 gallons
    Pool Type: Aboveground
    Pump:Hayward 1 1/2 HP Power Flo Matrix 2 Speed
    Filter: Hayward S230T 250lb Sand Filter
    Apr 2014
    CT
    26
    Re: Foam Bottom
    curious as to how you make out. I was considering using the foam as well... but was concerned about this very issue.
    Also - when installing the foam on top of the compacted sand... is the top of the foam supposed to be even with the bottom rails? or if the sand is even with the bottom rails and you install to foam on top... is that ok?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Foam Bottom
    It probably won't hurt anything, and if it doesn't bug you then I'd just let it be.
    Jun 2013
    Middlesex County/VA
    50
    Re: Foam Bottom
    We made out fine. I believe the issue was the installer cut and taped the bottom in before installing the wall. In installing the wall and readjusting as it was not situated the way I wanted it I believe it was separated then. It also was not taped enough in my opinion based on leftover tape. I was not there unfortunately and my wife did not know any different. They did not put sand down and providing you level the earth and compact it is not necessary in my opinion. I have not been in the pool yet but can say outside of the few gaps and few wrinkles left behind it is super smooth looking. I used 1 inch rigid foam.
    Quote Originally Posted by bobct1 View Post
