Thread: How do you remove a waterway poly jet?
    Jul 2012
    Duluth, GA (ATL)
    121
    I have this 8yr old Spa (built with my pool) and I have 6 of these Waterway Poly Deluxe Jets. Different types. Some of them I can turn then counterclockwise to essentially run full flow and clockwise to cut down the flow. But I cannot get the entire jet off. I see some pictures that seem to show its threaded but I don't see how Im going to unthread it out as it doesn't seem to turn past the stop when its set to full flow. Some of them I cant even turn due to the plaster/pebbletech sort of keeping it from turning.
    Id like to remove some of them like the spinner ones where its not spinning as well as it did new and just replace it.
    Here is a picture of what one of them looks like.
    Picture of Pool
    14,000 Gallon Freeform Plaster based pool. 1,000 Gallon Spa with Spillage Basin. Jandy Aquapure Ei Salt Water Chlorine Generator. Jandy CL580 Cartridge Filter. Sta-Rite P6E6G-208L Filter Pump. Jandy JHP2.0 Spillage Pump. Jandy LX400 Heater. Caretaker 99 Floor cleaner. Polaris Leaf-B-Gone. iAqualink.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: How do you remove a waterway poly jet?
    I think it is another 1/2 turn beyond the stop much like these:
    https://www.youtube.com/watch?v=ooaUUqd-Wmk
    Mark
