Results 1 to 14 of 14
Thread: Gunite retaining wall waterproofing
    Jul 2008
    San Diego, CA
    18
    My wife and I just purchased a home with an IG gunite kidney shaped pool. The rear wall of the pool extends about 3.5' above the water level and serves as a retaining wall for the slope behind it. This wall has a flagstone veneer placed over it and I have noticed what looks like water seeping out some of the grout lines probably from irrigation of the slope above. I don't believe the rear of this wall was ever waterproofed and am wondering if this is a standard practice when a gunite retaining wall is built. My plan is to remove enough dirt behind the wall to install a french drain near the waterline if there is not already one there and then apply a waterproofing material to the rear of the wall before backfilling it. Does this sound like the correct method of repair for this issue? There is also a waterfall at the top of this wall that flows down over the flagstone and has eroded some of the grout joints. Is this something that can be prevented or will it be something that I need to regrout annually or as needed?
    Thank You,
    Derek
    13,000 gallon inground gunite pool/spa. 2hp Whisperflow Pump, Pentair cartridge filter, Nature Soft SWG, Waterfall, Hayward Navigator.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Gunite retaining wall waterproofing
    Welcome to TFP....
    I don't mean to be rude but...
    We love pics....
    Jul 2008
    San Diego, CA
    18
    I knew that was coming!!! My first post was from work where I didn't have access to any photos. Here you go. I understand the efflorescence underneath the waterfall but am concerned about the leaching in a few other location which I have taken pictures of. I also included a photo of a crack below the coping at the skimmer that I need to repair. Any tips for that one?
    Jul 2008
    San Diego, CA
    18
    more pics
    Jul 2008
    San Diego, CA
    18
    One more
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    Hello Derek
    That plan of attack sounds good, make sure you buy a good quality sealer, and give it a few coats. At least three.
    With the grout just regrout it it should last a long time, also that might mean a poolwater balance problem. you can check your CSI on the pool calculator.
    good luck
    Happy swims
    Frank
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
    11,969
    Despite the troubles, it's sweet!!!!
    Jul 2008
    San Diego, CA
    18
    Quote Originally Posted by frustratedpoolmom
    Thank You we are really enjoying it.
    Jul 2008
    San Diego, CA
    18
    Quote Originally Posted by frankthailand
    Hello Derek
    good luck
    Happy swims
    Frank
    Sounds like I have a lot of digging in my future! I think the cracking around the coping is just from the initial settling of everything. I say this because in talking to the neighbors we have learned that the pool and patio are only about 2 years old.
    Rocklin, Ca
    467
    It is common practice to waterproof the back of retaining walls and install a french drain at the bottom. Normally the french drain needs to be sleeved to keep roots and soil out and also should be covered with a fair amount of gravel. Your raised bond beam does not have a bottom like a conventional retaining wall so I don't know how you deal with that. Maybe you can create a false bottom.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    Jul 2008
    San Diego, CA
    18
    Quote Originally Posted by cobra46
    I am not too concerned about creating a false bottom as I am only concerned with water trapped behind the wall and above the water line. I plan on waterproofing the wall and then encasing a sleeved drain pipe with fall of about 1/4 per foot in about 1' of 3/4" gravel at the bottom before backfilling.
    I am just surprised that this was not done when the pool was built in the first place.
    revstriker's Avatar
    Apr 2008
    Texas
    117
    Quote Originally Posted by spartanduner
    Just a thought.... I know that some do this when adding a French drain around a house: If you add some heavy gauge plastic under the stone, and under the French drain, this will force more water into the drain and out from behind the retaining wall instead of letting water filter down which could create pressure on the pool wall. I've seen this done to prevent the water from draining down and pressing against a basement wall.
    As I said, just a thought, but it probably wouldn't hurt, and woudn't cost a lot.
    10K White Plaster Pool Built in 2007. Hayward Pump and DE Filter, Hayward Navigator, Liquidator (Removed due to issues), Solar Blanket, BBB user.
    Jul 2007
    Suwanee, GA
    528
    I just did something similar when I found that water was leaking from the bottom of my slide and washing a bit of mud into the pool. I fixed the leak with the slide plumbing, but decided to go 100% and improve the drainage behind the wall and seal up the slide really well. I dug down to the water line, put down a drain pipe with landscape fabric underneath, ran rocks wall the up the wall and separated the rock from the backfill with the fabric. This way any water that washes down the top of the dirt will fall through the fabric and into the rocks where it will drain away.
    I had to dig a bit extra to find the 4" drain for the decking and tie the new drain into that. Lucky I had pictures of when I put that pipe in so I knew where to find it. That was a royal pain in the #*@&$& as the pipe was about 4' straight down and I had to go in head first to connect it.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    285
    I like using the MiraDri product. It's a self-adhering sheet membrane. Very sticky and very thick. It's like contact paper -- just clean off the wall, let dry and stick. It'll stick to the next sheet to create a joint so well you'll never get it off. One person can do the installation, but it's easier with two (once it touches something, it does not want to come off).
    For my taller walls I also put a MiraDrain in that channels the water to the drain at the bottom. I don't think I'd do that again. I can't see it doing much more than the MiraDri itself and it adds $$.
    http://www.carlisle-ccw.com/Doco/ccw-mi ... 60-861.pdf
    The French drainis a must, but also put in surface drains to keep the water from having to go through the soil. Any water taken out of play before it hits the waterproofing is good. I never tie surface drains into a french drain system, as it channels the water down to the base of the wall into a pipe with holes (yes it can work in reverse also).
    Steve
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
