Results 1 to 12 of 12
Thread: Getting started
    May 2014
    Texas
    5
    Getting started
    Ok I'm not a pool guy. I have had an underground pool for two years and have been fighting it everyday. My uncle turned me on to this site and told me to get a good test kit first. If ordered one and it should be here tomorrow My pool of course is green because I wanted to start right instead of buying a bunch of useless chemicals from the local pool shop. Keep in mind I live out in the country. I though by asking people who have had success with there's and have the best way of doing this. Lets just say I have no chemicals anymore I would like to stock all the chemicals I would need. When I get the test results I will post them as well. But for now a list of chemicals would be great. Thanks so much
    38,524
    Re: Getting started
    Welcome to TFP!!
    Bit of a chicken and egg thing here ... we can not give you recommendations on what chemicals to buy until you give us test results.
    What test kit did you order?
    You will certainly need bleach, but that is all we know for now.
    You will need to go through the SLAM Process so read up on that and these:
    Defeating Algae
    Turning Your Green Swamp Back into a Sparkling Oasis
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Please add your pool details to your signature and location to your profile as described HERE as it will help us help you.
    May 2014
    Texas
    5
    Re: Getting started
    Welcome to TFP!!
    Defeating Algae
    Ok I'll get on top of that. I ordered I think it was to T-100. I'll post and fill out rest of profile once I get text results. Thank you much
    Casey's Avatar
    SW PA
    10,461
    Re: Getting started
    Welcome and congrats on taking control of your pool by buying a great test kit! You're going to wonder how you got through without it for so long! Read pool school while you wait for your kit. Your pool won't get any greener! So far, the only thing I suggest you buy is unscented bleach and keep it in a cool dark place.
    If you do the reading and learning, we can help with questions and you'll be off to enjoying a TFP!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Getting started
    Welcome to TFP !
    Jeff
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Getting started
    Welcome!
    How about posting a "before" picture?
    You'll appreciate having it in about, oh, two months, when your pool is sparkling and troublefree and you are bored with it because it's so easy to take care of.
    May 2014
    Texas
    5
    Re: Getting started
    Ok not only am I bad with pools I will have to learn to use this site as well. So far the remarks are great and well appriciated Ok got the test results from the TF- 100
    Daily test-
    PH - 8.2
    Chlorine - 0
    Weekly
    Chlorine 0
    CC -1.5
    Calcium - 200 ppm
    TA - 80
    CYA - 20
    My best calculation guess is around 25,000 gallons it is a gunite pool and the temp is about 70 degrees. The degrees doesn't sound right but that's what it reads. I'm reading up on the school as well. When u say bleach you mean like at the super market?
    38,524
    Re: Getting started
    Yes plain old bleach (usually 8.25% strength) which is the same as liquid chlorine sold in other places which is a little stronger at 10% or 12.5%.
    Based on those results, you need to lower the pH to the lower 7s and then SLAM away.
    You will eventually want to bump up the CYA a bit as well.
    Casey's Avatar
    SW PA
    10,461
    Re: Getting started
    When you get some down time, click on Pool School (top right of every page) and just look around. You'll get used to the site the more you frequent. If you can't find something, just ask and we can help!
    May 2014
    Texas
    5
    Re: Getting started
    OK im starting to get the feel of what i need to do by reading up on things in the pool school the site is great and the help is fantastic. Two more questions before i start the slam process tomorrow. With a pool of 25,000 gallons how many gallons of liquid bleach would i start with. My chlorine is 0 and how many gallons of acid should i use to start bringing my PH down. my PH is 8.2. I have never used liquid bleach to do this so its new to me and i didnt see any mention of this in the pool school. Oh and where do you get DE at for your sand filter? I have never heard of that. Thanks,
    Pentair sand filter , Hayward 1.5 pump
    Plaster pool bout 25,000 gallons bout ten years old is a guess.
    38,524
    Re: Getting started
    Ok, now your next task is to learn to use PoolMath
    It will do the calculation for you. You set the pool volume and the NOW column based on your test results and then set your desired levels in the TARGET column (do not use the defaults). And it will tell you what would need to be added.
    pool DE is available at most large hardware stores or pool stores. Walmart often has smaller quantities ... you will not need much for occasional supplementation in a sand filter.
    May 2014
    Texas
    5
    Re: Getting started
    Thanks
