Thread: Deep skimmer vortex
    May 2014
    dartmouth, ma
    6
    Deep skimmer vortex
    Hi
    We've moved to a house with a new pool. Used a couple of months last august. Noticed that the deep skimmer which is farther removed from the pump than the shallow skimmer will vortex, and eventually suck air. Last fall I added water (about 4 inches) to get this to stop. Had to do again in a month before closing. Opened the pool. same thing 2 days after having the pump on. Water level didnt seem to drop more than an inch.
    A couple of points thoughts, in addition to what might be a pipe leak (lower water level over time)
    1) deep end skimmer might simply vortex first because its maybe not level with shallow skimmer
    2) the pool plumbing is 2 inch pipe, the pump 2 hp, a pool guy said the pump is big for the filter
    3) the return flow pushes through eyeball jets, so possibly constricted outflow.
    Im wondering if there is simply a large suction vacuum from the skimmer side to the pump (pump filter is 18 lbs pressure) and pressure build up on the outflow side? or am i making this too complicated?
    thanks in advance!
    38,262
    Re: Deep skimmer vortex
    Welcome to TFP!!!
    Do you have a float diverter under the skimmer baskets? That could be used to lower the suction. Or you could just put a big rock in the skimmer basket to disrupt the vortex ... assuming the water level is adequate.
    May 2014
    dartmouth, ma
    6
    Welcome to TFP!!!
    I do not know if I have a float diverter, will check! Big rock not a bad idea. I realized last night that I have not been filling up water level to half way up the skimmer's. So will do that, and also put a marked bucket in to see how quickly my water level goes down. I remember last fall adding what seemed like 4 inches of water a couple of times, which is allot of water for a 33k gal pool. That said, I was using the heat pump, it was cooler and windy in NE.
    Thanks!
