Thread: What should I do until refills arrive?
    May 2008
    Northern Virginia
    30
    After finally getting a stubborn algae problem under control (I think) my pool is finally in good shape. As many other new members have learned, I underestimated how much bleach I would need and how much I would have to stay on top of the problem.
    Here's my new dilemma:
    The water looks great, but I ran out of the R-0871 solution and don't know the exact chlorine level. I ordered refills on Friday, but given the July 4th holiday figure it will be at least a couple days before it arrives. I should have reordered earlier.
    When I last tested a couple days ago:
    TC was 30
    PH 7.2
    CYA 60
    The chlorine levels are off the scale of the basic kit and some leftover test strips.
    So should I allow chlorine levels to drop down to normal levels or keep it somewhat higher while blindly adding bleach for a couple days until refills arrive? I called a couple pool stores and they can't test over 5 ppm.
    Thanks
    _______
    35,000 IG vinyl with new Hayward Sand filter in 2006, chlorinator, Hayward 1.5HP Super Pump, Polaris with own pump, gas heater, 2 skimmers, 2 returns, no main drain.
    austinsmom01's Avatar
    Jun 2008
    Georgia
    163
    Re: What should I do until refills arrive?
    For your size pool, with a CYA of 60, shock level would be 18. At 30 I think you'll be fine for a day or two until your refill arrives. I wouldn't add any more (until you know your exact level) or you'll run the risk of damaging your liner.
    I'm 2 weeks into an algae fight and I'm winning! Thanks to these guys/girls of course!!!!
    15,400 gal. IG Gunnite
    1.5 hp Champion Pool Pump
    3/4 hp Century Pool & Spa Motor
    Pentair Automatic Chlorine Feeder
    Crystal Water Pool & Spa Cartridge Filter
    Polaris 280
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Actually shock level for a CYA of 60 is 24ppm
    I don't advise blindly adding bleach, but I don't want your water to get icky again either.
    You can try the "dilution method" with the OTO test, using distilled water. Do a "search" for dilution method.
    IT's a really rough estimate, not entirely accurate, but better than guessing and putting in too much bleach and damaging your pool.
    Quote Originally Posted by frustratedpoolmom
    That depends on who you ask. I say 18, others say 24. Either one will work, 24 will work more quickly in some cases.
    11,969
    Just going by the chart in Pool School.
