Results 1 to 1 of 1
Thread: Modifying Summer Escapes Pool
    Apr 2014
    United States
    4
    Please do not hijack and raise old threads. Make your own thread so you can get specific advice to your pool. Casey~
    I have the same question as here. I have a Summer Escapes 18' X 48" and I am replacing the stock skimmer and pump with an Intex 633T 2500 GPH. I got the Hayward SP1091LX Skimmer on Amazon for only $31 (Great quality, and include fittings and vacuum plate too). I also want to use the suction strainer wall port that comes with the pump. My plan is to mount it as low as I can, and then use ball valves to balance between the two. The Cantex 5133719C ADAPTER BOX 1-1/2" takes care of your Intex fitting problem perfectly. They seal in just like the hose end and glue to 1-1/2" PVC. My only worry is cutting a new hole down low. Wondering if it sees more pressure. I'm thinking of a hard pipe union at ground level, and then a foot of spa hose flex pvc for movement. My low return will probably be at least 18" off the floor so it might be too high to clean the bottom well unless I pipe back down, but grabbing some colder bottom water has to be good for circulation and heating.
    Just noticed how old this was. I'm guessing you already got what you need.
    Last edited by Casey; 05-13-2014 at 12:14 PM. Reason: Made new thread for peteshutup
