Thread: Vacuum Question
    Mar 2013
    CT
    351
    Vacuum Question
    This is my second year with my in ground pool so I am still learning. I wouldn't have been able to do ANYTHING without this site. It's where I've gotten all my info I've had very few problems - even as a new pool owner.
    I have a question on vacuuming. When I was closing my pool last year I found I had two shut-off valves that take water from the pool. One from the skimmer and one from the bottom drain. When I vacuumed last year I never messed with these shut offs. Recently a friend of mine told me that I should shut off the main bottom drain completely when I vacuum. Is that accurate? Sounds reasonable to me but i don't make a move without checking with you guys first!
    Thanks!
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    38,520
    Re: Vacuum Question
    If you shut off the floor, you may end up with too much suction through the vacuum and not be able to move it. If you need more suction while vacuuming, then partially close the floor until you think it is acceptable. There is no right or wrong.
    Oct 2013
    Chapin, SC
    1,141
    Re: Vacuum Question
    I'll second that! From experience! I broke off the attach point on my vacuum head the first time I used it. It was pretty flimsy so I bought a noticeably stronger one. Since I have a Polaris 280 Vacuum that does a really good job of keeping the bottom of my pool floor clean, I don't even bother with the manual vacuum any more.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
