Thread: Flagstone on tanning ledge
    Aug 2013
    Maryland
    93
    Anyone have flagstone on their tanning ledge? Especially if you live in a frost prone climate?
    Plaster/tile crew highly advising me to avoid it in Maryland. Says stone will absorb water and crack from frost in the winter. Love the look though.
    Thoughts?
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Re: Flagstone on tanning ledge
    This is a link to our PB's website that contains many pictures of pools in MD or Northern VA with stone on tanning ledges. We do not have it and I would have some of the same reservations as well. James, the owner, is great to discuss things like this with if you were interested in having them quote your pool. The look is gorgeous to my eye.
    I would think you'd certainly need to keep the water level below the ledge level all winter, which would mean judiciously pumping out water (if you use a mesh cover or solid with drain panels). Though covers also need the water level to be within x inches of the coping surface to not void the warranty (and not stretch/break them). So there would be little room between your low and high water levels. But these are just my thoughts and could be inaccurate.
    http://www.themarylandpoolbuilders.com/portfolio.php#
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
