Thread: new pool just opened... test results.... advice needed
    Jul 2013
    western new york
    62
    Last fall I had a fiberglass pool installed .. I got to swim in it twice before it was closed. I had the people who installed the pool open it on May 9th.
    after they shocked it, I waited 24hrs. and tested with a taylor test kit. Cl is 5ppm; Ph 7.5; CYA 10 ( added a little stabilizer and need to wait a few more days to retest) My Ca hardness is low about 140-150 and TA is 140 as well.
    I see the recommended levels for Ca (fiberglass pool) is 220-320 My question is: Any problem to gradually raise this with Cal Hypo before switching over to bleach?
    What about the TA? I see 70-90+ is recommended. how much + is ok (again I'm at 140)
    btw the water looks nice and clear
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,991
    Re: new pool just opened... test results.... advice needed
    You have grasped the TFPC method. Using Cal-hypo is fine. You want that side effect.
    The TA will come down all by itself if you just maintain pH. Don't fuss with it unless you are having one of the two problems specified in the article in Pool School.
    Raising CH slowly is just fine.
    On TA, as long as your PH is relatively stable, there is no reason to worry about TA. If your PH is constantly going up, you will want to lower TA.
